parts for 8n in Alberta or where?
   / parts for 8n in Alberta or where? #1
mogdriver
Ponoka, Alberta
1947 Ford 8n
Hi, just joined the forum. Already reading some wonderful information and advice. Just wondering where I would find parts? In Alberta? online stores? ebay? the usual tuneup parts, etc
thanks
   / parts for 8n in Alberta or where? #2
not sure what stores you have there.. but if you have napa or places that can cross napa or bluestreak / standard ignition numbers, tune up parts are pretty common.
here's a list I have compiled... has front and side mount distribuitor listings
Here is a list of Oil Filters for 8N and other Ford tractors.
Ford Part Number: CPN 6371B 9N-18649, 9N-6714, 9N-2731
Fram C3, C3-P
NAPA Gold 1010
Motorcraft FL 144
Balidwin P40
Big A 92010
Bosch 72127
Carquest 85010
Fleetguard LF574
Wix 51010
Purolater L20110 or L20701
Fleetrite LFR-8574
Texaco HSO-100
Unocal OF 1010
White 10575
Hastings Mighty M3LF-130
Luber-Finer P3
Ignition Parts:
Front Mount distributor...
NAPA #CS35
Standard Ignition Blue Streak #FD-6769X (Premium)
Condensor:
NAPA #FA200
Standard Ignition #FD-71
Rotor:
NAPA #FA300
Standard Ignition #FD-104
Distributor Cap:
NAPA #FA350
Standard Ignition #FD-126
Side-Mount Distributor: 8n thru 4 cyl thousand series
NAPA #CS749
NAPA HEAVY DUTY PIERCED (ventilated) #CS753
Standard Ignition #FD-8081
Standard Ignition Blue Streak #FD-8081X (Premium)
Condensor:
NAPA #FA66
Standard Ignition #FD-75
Standard Ignition Blue Streak #FD75X (Premium)
Rotor:
NAPA #FA67
Standard Ignition #FD-108
Distributor Cap:
NAPA #FA352
Standard Ignition #FD-128
side mount points hold down screws #8-32 X 3/16
FORD AUTOMOBILE dealer parts counter. come with built-in lockwasher. p/n 355047-S7 (#8-32 X 0.19)
Thanks so much for the information! wow! there is a NAPA dealer in town, they just opened last year.
regards
Bob in Ponoka
   / parts for 8n in Alberta or where? #4
good luck!
got the tractor running. I had gone to NAPA before you (Soundguy) had posted this list and picked up a battery ground cable and 4 new spark plugs. I drained the old gas and cleaned up a few things. Took a couple of days of troubleshooting and it turned out to be the discharge nozzle in the carb being plugged and the ignition key being intermittent.
It ran for about an hour, I managed to plow a bit of snow... yes, still snow on the ground here, lol. then it started surging, engine revving up and down. I managed to make it back to the shop and discovered the little T drain valve had backed off causing fuel to drain out of the carb... my bad, I probably had overlooked tightening it up.
just need to find a parts supplier for various items
   / parts for 8n in Alberta or where? #6
what items...over the years I've come across QUITE a few N parts sellers..
soundguy
2017 Ford F-150 Pickup Truck (A50323)
2017 Ford F-150...
Tri-Axle Police Travel Trailer (A51694)
Tri-Axle Police...
2018 Ford F-350 4x4 Crew Cab Pickup Truck (A50323)
2018 Ford F-350...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2019 Ford F-150...
2000 International 4700 (A50120)
2000 International...
16FT Flatbed Trailer (A51573)
16FT Flatbed...
