Parts Diagram and/or Owners Manual for Century 2535 (made by Kukje) tractor
   / Parts Diagram and/or Owners Manual for Century 2535 (made by Kukje) tractor #1
DonWannaBother
South Carolina
Century (Kukje) 2535
I've searched the web on and off for years. Best I found is a Branson 25-Series Owners manual, which is similar, but not the same. If anyone has a PDF, or knows a site where I can find replacement parts...
Here's what I know:
This tractor was made in 2002-2004 in the Yangsu-ri factory in South Korea.
Oil Filter: Napa Gold 1344 (Replaces HHI 1050000A4)
Air Filter:
Outer: Napa Gold 6438
Inner: Napa Gold 2985
Fuel pump relay: Napa AR282
Bolts are mostly or all Metric.
In case you can't tell, the nearest parts store to me is a Napa. :)
   / Parts Diagram and/or Owners Manual for Century 2535 (made by Kukje) tractor #3
Thank you for supplying the info you have on the 2535. I also have searched high and low for a manual on this tractor, for some time now.
I am trying to find out exactly what kind of hydraulic fluid to use in my 2535. I was wondering what kind you use in yours? Any help you can give me will be greatly appreciated.
I want to give you this info,in case you don't have it: Posi-Flow TM
EFP-3
universal electronic fuel pump
US PAT# 7150606
   / Parts Diagram and/or Owners Manual for Century 2535 (made by Kukje) tractor #4
Facel
Posi-Flow TM
EFP-3
us pat. #7150606
   / Parts Diagram and/or Owners Manual for Century 2535 (made by Kukje) tractor #5
I have the Century manual for a 2535 and the shop manual for it. Mine is a 2004 model. It is not bound so that it can be easily scanned, but if there is a particular section you need let me know and I will try to scan it. I have had good success with the universal tractor hydraulic/ transaxle fluid from tractor supply. I have over 1500 hours on the tractor now. W. Jones
   / Parts Diagram and/or Owners Manual for Century 2535 (made by Kukje) tractor #8
According to what I have found, the 2535 has the 3T90LT-ATC which is what I have. Would it be possible send me or attach (to a reply) a scanned copy of the section that has part numbers for the injectors. Would be greatly appreciated, thanks.
   / Parts Diagram and/or Owners Manual for Century 2535 (made by Kukje) tractor #9
Ok give me a bit of time today to go get the manual and scan the relevant pages. I have replaced the glow plugs on mine, but have never touched the injectors.
   / Parts Diagram and/or Owners Manual for Century 2535 (made by Kukje) tractor #10
Ok here are the parts from my parts manual. probably there is a different number, but a dealer should have the change.
  • Scan.pdf
2008 Ford F-250 4x4 Knapheide Service Truck with Liftgate (A51692)
2008 Ford F-250...
NEW Wolverine Skid Steer Bucket Root Rake Attachment 34'' (A53002)
NEW Wolverine Skid...
2003 CATERPILLAR 277 SKID STEER (A51246)
2003 CATERPILLAR...
2016 Ford F-550 4x4 12FT Landscape Dump Truck (A51692)
2016 Ford F-550...
JOHN DEERE 4730 LOT NUMBER 274 (A53084)
JOHN DEERE 4730...
1999 Ford RV , VIN # 3FCMF53S2XJA29020 (A51572)
1999 Ford RV , VIN...
