Parts Diagram and/or Owners Manual for Century 2535 (made by Kukje) tractor
   / Parts Diagram and/or Owners Manual for Century 2535 (made by Kukje) tractor #1
DonWannaBother
South Carolina
Century (Kukje) 2535
I've searched the web on and off for years. Best I found is a Branson 25-Series Owners manual, which is similar, but not the same. If anyone has a PDF, or knows a site where I can find replacement parts...
Here's what I know:
This tractor was made in 2002-2004 in the Yangsu-ri factory in South Korea.
Oil Filter: Napa Gold 1344 (Replaces HHI 1050000A4)
Air Filter:
Outer: Napa Gold 6438
Inner: Napa Gold 2985
Fuel pump relay: Napa AR282
Bolts are mostly or all Metric.
In case you can't tell, the nearest parts store to me is a Napa. :)
   / Parts Diagram and/or Owners Manual for Century 2535 (made by Kukje) tractor #3
Thank you for supplying the info you have on the 2535. I also have searched high and low for a manual on this tractor, for some time now.
I am trying to find out exactly what kind of hydraulic fluid to use in my 2535. I was wondering what kind you use in yours? Any help you can give me will be greatly appreciated.
I want to give you this info,in case you don't have it: Posi-Flow TM
EFP-3
universal electronic fuel pump
US PAT# 7150606
   / Parts Diagram and/or Owners Manual for Century 2535 (made by Kukje) tractor #4
Facel
Posi-Flow TM
EFP-3
us pat. #7150606
   / Parts Diagram and/or Owners Manual for Century 2535 (made by Kukje) tractor #5
I have the Century manual for a 2535 and the shop manual for it. Mine is a 2004 model. It is not bound so that it can be easily scanned, but if there is a particular section you need let me know and I will try to scan it. I have had good success with the universal tractor hydraulic/ transaxle fluid from tractor supply. I have over 1500 hours on the tractor now. W. Jones
   / Parts Diagram and/or Owners Manual for Century 2535 (made by Kukje) tractor #8
According to what I have found, the 2535 has the 3T90LT-ATC which is what I have. Would it be possible send me or attach (to a reply) a scanned copy of the section that has part numbers for the injectors. Would be greatly appreciated, thanks.
   / Parts Diagram and/or Owners Manual for Century 2535 (made by Kukje) tractor #9
Ok give me a bit of time today to go get the manual and scan the relevant pages. I have replaced the glow plugs on mine, but have never touched the injectors.
   / Parts Diagram and/or Owners Manual for Century 2535 (made by Kukje) tractor #10
Ok here are the parts from my parts manual. probably there is a different number, but a dealer should have the change.
  • Scan.pdf
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
2017 Nissan Maxima Sedan (A50324)
2017 Nissan Maxima...
2016 POLARIS RANGER ETX EFI 00HC RTV (A51243)
2016 POLARIS...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2015 Dodge Challenger Coupe (A50324)
2015 Dodge...
