Particle Board
/ Particle Board #1
Tdog
Platinum Member
SE Louisiana
BX22
My wife 'had' to have a closet organizer that she saw in Lowe's. It is construced of particle board with a white finish. I want to notch out a section for the baseboard to make the unit sit flush against the wall of the closet. However, I'm afraid this stuff will flake off when it is sawed. I'm thinking about clamping on a wood backing & cutting with a fine tooth blade in a jig saw. Any thoughts? Am I being overly cautious?
thanx
jack
/ Particle Board #2
You shouldn't have any problems cutting it. If you want a nicer finish sandwich the piece that you need to cut between fiberboard and cut through all 3 thicknesses. It will keep the edges from chipping while cutting. Have also used duct tape stuck to painted particle board and simply cut through that but the results vary.
/ Particle Board #3
Right. The particle board won't flake but the cut line will have small chips in the finish. Tape, sandwich help, also you can scribe the cut line with a sharp knife before cutting.
Harry K
/ Particle Board #4
Pay attention to the cut of the blade. Depending on what type of saw you decide to use will determine which side to cut. One side will be perfectly smooth, the other will have some minor chiping. The finer the blade, the smaller the chips. But even with an aggressive blade, one side will be allot smoother than the other.
Eddie
/ Particle Board #5
Sears sells some nice holloow ground jig/sabre saw blades that cut super smooth and have virtually no splintering on any wood.
Try some you will like them /forums/images/graemlins/smile.gif
The teeth look like hollow ground X's from the front edge rather than regular teeth, cut fast and smooth.
Others might make them , but I found them at sears many years ago and love em. I use em to cut nativity siloutes from plywood and require no sanding on the edges /forums/images/graemlins/smile.gif
Ben
2017 JOHN DEERE 317G SKID STEER (A65053)
2017 JOHN DEERE...
2017 Cadillac Federal 70IN Limo w 27466 Miles, Premium Federal Coachwork, Luxury Transport (A63688)
2017 Cadillac...
New/Unused ATS Electric Jack (A65583)
New/Unused ATS...
2019 FORD F-150 XLT CREW CAB TRUCK (A63276)
2019 FORD F-150...
2003 Chevrolet C7500 Flatbed Truck (A62613)
2003 Chevrolet...
New/Unused Landhonor 12V Diesel Pump (A65583)
New/Unused...
