Partial Failure of curl down
   / Partial Failure of curl down #1
Dave Pee
Live Oak, Florida
JD 2032R 2015
JD 2032r 10 months old, in warranty, but shop is closed today.
Trying to do sand leveling in reverse, with front bucket, pointed straight down; hydraulics do not hold it, and the bucket just curls up.
Can also curl the bucket 1/2 way, by hand; at the 1/2 way point, it stops.
Can load and unload sand from the bucket as normal; curl and un-curl seem fine, no flopping around.
Hoses and connections and cylinders appear fine. Fluid level is fine.
Only scenario that even begins to make any sense, is if one curl cylinder had a pistol failure some time ago, and today the second curl cylinder had a similar type failure.
What do you more experienced folks think??
TIA Dave :confused:
   / Partial Failure of curl down #2
Yea, the seals in the cylinders aren't strong enough to support back dragging. All tractor loader manuals specifically state this as an action that will void the warranty. Time to rebuild the cylinders...
   / Partial Failure of curl down #3
Back blading with bucket straight down you can bend the cylinder rods .
   / Partial Failure of curl down #4
Hold it in the curl position till it stops moving. Let off, do it again and hold it. It'll curl and be locked where you want it.
Brett
Brett - I don't understand what you are trying to say.
FYI: JD manual says to keep a 40 degree angle when back-blading.
   / Partial Failure of curl down #6
With that kind of angle, and the lift arm in "float" mode, you'll avoid any high pressures in the bucket cylinders as the bucket follows the earth's contours. Straight down at 90° you could over pressure a hose if you hit one of the the innumerable immovable objects found in the earth. Heck, my bucket free-falls at that sort of angle (assuming a valve issue, don't care 'cuz I'm replacing the valve).
   / Partial Failure of curl down #7
Not going to argue about weather one should back drag, and how it should be done. MAny people do it all the time and no issue. Some have issues bending rods and popping hoses.
But none of that is relevant to why the bucket wont hold position. Piston/seals have nothing to do with weather the loader will hold position when back dragging. Because you are trying to compress the cylinder. And the ONLY way for that to happen is either you have air in the cylinder, or oil is leaving the cylinder.
Well, if there are no leaks, and you joystick valve centered....the oil aint leaving. So that only leaves air in the cylinder..
And thats actually a common problem on the curl circuit if the valve doesnt have regen. (or if you arent dumping using the regen function) dont know which applies to you/tractor
Basically what is happening is when dumping the loader, (especially at idle and/or with a load) is gravity is dumping the bucket FASTER than it can be filled with new oil. This results in a cylinder half full of oil, half full of air. Air compresses, oil dont. Thats why it only wont hold, up to a point then will feel rock solid. Because you compressed all the air, and now pushing on the oil.
How to prevent this......
IF your valve has regen....use it to dump. (some valves have two functions when dumping that you have to push past the detent. Sorta like lowering the loader....then pushing past that detent into float)
IF your loader dont have that, dump the loader ALL the way til it hits the stops. Then hold the lever there for a few seconds to purge all the air out. THEN curl back to whatever backdrag angle you want.
Nothing wrong with the tractor IMO, and I wouldnt waste the dealers time til you at least try that.
LD - you may be right about air in cylinders. I tested it this morning, and cycled it a couple of times - seems like the play is now just one inch or so (of the bucket).
I will double check, but i don't think I have a regen feature.
Thanks to all!
Dave
   / Partial Failure of curl down #9
Thanks to all!
Dave
Its a common issue on loaders that dont have regen, or operators not using that function
   / Partial Failure of curl down #10
It's not air in the cylinder. All my deeres have done this. Get the bucket where you want it but put some pressure on it. Let off the loader control valve. If you start back dragging, it'll curl up right? Get back on the curl and hold it to curl it down. You'll feel it start to move the tractor. When it'll support the tractor your good to go. I can send you my number and walk you thru it. I'm not doing a good job articulating it but it's very simple. When it stops curling back, stop and do it again. It'll be good to go.
Brett
17604 (A51694)
17604 (A51694)
2008 Ford Escape Hybrid SUV (A51694)
2008 Ford Escape...
2004 FREIGHTLINER CL120 TANDEM AXLE SLEEPER TRUCK (A52577)
2004 FREIGHTLINER...
2007 Toyota Corolla Sedan (A50324)
2007 Toyota...
2004 PROCO 130 BBL VACUUM TANK TRAILER (A52472)
2004 PROCO 130 BBL...
