Part out or repair
   / Part out or repair #21
Insurrance adjusters have a lot more experience with fire damage than the average bear. The reason they did not "salvage" it, after the total, it was not worth the transportation coast to a salvage yard for auction.
In the business that is a constructive total loss, costs more in parts and labor to repair than it's worth.
If you have to haul it to the scrap yard, that tells you all you need to know.
   / Part out or repair #22
Years ago when I worked for an ag dealer. Combines seemed to have an odd habit of catching fire. Well most just destroyed the area around the engine and operators cab. Yes I get the job of repairing them. One comes to mind that had the cab gutted and of course the engine area took a hard hit. It had caught fire, the operator put the fire out. Started the engine and started cutting again, once again he smelled smoke and but the new fire out. Checked and cleaned the area of the fire OK good to go. Started cutting again again smelled smoke, Now fire extinguisher is dry, called the fire company (they were close) Put the new fire out, but this time too damaged to run. Took it to the shop and started repairing it. All the electrical, fuel pump, filters, and even fuel injection pump. Got to the point of being able to run the engine. and could not find where a oil leak was coming from. Finally found the fire had melted a small hole in the valve cover, it was aluminum. Finally got the engine working, the electrical working and put the thresher in gear. There was a shaft behind the engine about 3 inches in diameter about 5 to 6 foot long. Each end of that shaft had a belt on it that pulled on the shaft. As I put the thresher in gear I noticed the center of the shaft was not true but was bent. The fire had heated that shaft enough and with the belts pulling on the ends had bent the shaft.
So I am often leery of repair fire damage and have seen some easily repairable but some unless you are in love with the unit or it has a special meaning to someone AND you have deep pockets with lots of time to repair little aggravations It is best recycled.
Yes I have more stories of "burn" jobs but that is enough for now.
   / Part out or repair #23
I can't even believe this discussion is ongoing. That should have gone straight to the scrap pile while prices were up this summer.
   / Part out or repair #24
I don't recall anyone successfully rebuilding a burned over piece of farm machinery...or a motor vehicle, for that matter. Just not worth the time. Probably not even worth trying to part out.
   / Part out or repair #25
I wouldn't want to be around when they put tires on those wheels and aired them up; tires burn hot, and I'm sure that the inegrity of the steel has been compromised. Why even take a chance?
2017 Hitachi Zaxis ZX130 LCN-6 Hydraulic Excavator (A57453)
2017 Hitachi Zaxis...
1604 (A57192)
1604 (A57192)
Pallet of UV Solid Hardwood Flooring (A55758)
Pallet of UV Solid...
2017 DODGE RAM 3500 DUALLY (A58214)
2017 DODGE RAM...
MINI KID DIRT BIKE (A56859)
MINI KID DIRT BIKE...
205196 (A52706)
205196 (A52706)
