part for IH 274 diesel
/ part for IH 274 diesel #1
Chick Leeper
I am searching everywhere for a u joint on the steering shaft where it connects to the gear box. Does anyone have any idea who might have it?
My tractor is a 1983 International 274 diesel.
/ part for IH 274 diesel #2
I would take the u-joint up to a good auto parts store that sells parts for autos, farm, and big trucks and see if they could match your u-joint up. Alot of u-joints are a standard size not sure about your application, but it would be worth a try and propably cheaper than a tractor parts dealer.
Thanks Matt, I've tried that. The problem is that parts for 274 will only fit 274 and there is nothing out there that corresponds or at least that I've been able to find.
/ part for IH 274 diesel #4
Well the tractor was made by Nissan according to TractorData, so you might find more leads going down that road if you could find a comparable model grey market Nissan branded tractor source for parts.
Otherwise, unless you have already done so, you could try taking a dial caliper and getting the spread dimensions on the joint + the diameter of the caps. Take those measurements and match them to a part # in the Neapco U-joint Catalog. I would be pretty surprised if there isn't a match in there.
Once you have your part # it will be a simple matter of finding a supplier who has or can order it for you.
2021 Kubota MX6000 (A62177)
2021 Kubota MX6000...
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A62131)
UNUSED WOLVERINE...
2016 Ford Escape SUV (A61569)
2016 Ford Escape...
Wolverine Universal Quick Attach Mounting Plate Skid Steer Attachment (A60353)
Wolverine...
UNUSED RAYTREE RMBD72 - 72" DRUM MULCHER (A62131)
UNUSED RAYTREE...
500 GALLON FUEL TANK (A62131)
500 GALLON FUEL...
