Part D prescription plan
   / Part D prescription plan #31
My wife and I have the "F" plan through Bankers Fidelity. She is four year older than I am. Hers runs 420, mine 220. We used to have our part D through Silverscript. I first changed only hers to Anthem Mediblue Rx Plus then the following year I kept hers on the Anthem plan but changed mine to Humana Value Rx.
She is on Eloquis and come about Nov of last year, we ended up getting samples from our cardiologist to get to Jan 1st due to the cost.
For 2025 my Humana plan goes from 39.10 down to 30.30. Her Anthem plan goes from 94.70 down to 87.10. I just started trying to discipher the changes.
For dental, I am fortunate to have UK's school of dentistry where as my wife is on an in-house plan though her dentist which is doable cost wise. Better than through any plans.
We log every trip to our doctor's. I think it was .22/mile that we could deduct on our federal taxes. Between our plan costs, etc., we can reach the deductable.
We both mostly see the same doctor's so it makes little sense for me to use the VA for other than my hearing aids or I would go there. That and it's a 75 mile one way trip.
One thing that I suggest is to follow your covered costs. Make sure that when you have a procedure, that you present your plans and that they are noted.
I had a hospital come back two years after my wife had surgery claiming that we had no secondary policy. My wife is hearing impaired and does not use a phone. (Caption Call does not work here, our phone line is too noisey) So, they would not talk to me. Twice, they never got my hppa form? Turned out they submitted improper forms to our secondary. Not sure why but after I sent my info to Medicare, I never heard from the hospital again?
I always go over our Medicare statements but not always the secondary. I do now. Also, I did report to Medicare at least three times that Covid tests kits were on our statements that we did not order nor receive. So watch for incorrect charges which effect everyone tax wise however trivial.
   / Part D prescription plan #32
Turns out my (Medica) part D is going up $20/mo. I think the legislating limiting max out of pocket t $2,000 has a lot to do with it. My agent said I should ask my pharmacy to run a Part D Prescription Drug Cost Calculator for me. It will show my total drug and premium costs for all kinds of plans. My pharmacist said he can do it after October 15.
   / Part D prescription plan #33
If you go to the official medicare web site you can view and compare every plan offered in your county. I just finished looking at my options tonight.
My current one would go up to $66 per month with a total cost for 2025 of about $2700,
I found another that should be just under $2000 for the year.
You can put in all your meds and it will show you the monthly and annual cost for each plan.
   / Part D prescription plan #34
Yep,
I can do it, or my agent can do it, but he said it's easier to have your pharmacy do it.
   / Part D prescription plan #35
you can also do this on the medicare.gov website
   / Part D prescription plan #36
wow ! My part D plan only went up $3.00 per mo . for 2025. ($43.00 per mo) I feel lucky
   / Part D prescription plan #37
Yep,
I guess I just may be different as I don't trust anyone to find out whats best for me, especially when it's fairly easy for me to check out all the available options for me including different pharmacys.
There were only 12 different plans available in my county. But the annual cost with all my prescriptions added in varied from $1980 to over $2700, I do take 8 different prescriptions at this time.
   / Part D prescription plan #38
My Wellcare PDP premium went from $ 0.50 per month to $ 0.00 per month. Annual deductible went up $ 45.00 and most co-pays increased $ 5.00
paul
   / Part D prescription plan #39
paul
I'm going to guess that you have an Advantage Plan, if I went with one of those it would cost me less. But I don't like the limitations it has.
   / Part D prescription plan #40
paul
My Wellcare also decreased to 0.00/mo. Annual deductible same as yours. All my current meds are still priced same as last year with only one that has a small copay. My wife's current meds also did not increase in copay
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A55302)
2024 BCL...
UNUSED Wheeled Dump Hopper (A47477)
UNUSED Wheeled...
John Deere 455G Crawler Loader (A54865)
John Deere 455G...
2014 Ford Escape SUV (A55758)
2014 Ford Escape...
2006 Peterbilt 335 Day Cab Truck (A53117)
2006 Peterbilt 335...
ATLAS 84" BOX BLADE (A51243)
ATLAS 84" BOX...
