parmi, lazyboy tiller
/ parmi, lazyboy tiller #1
podieroe
Sale Creek Tn
gravely 5260
i just bought a Parmi Tiller for little more than the cost of the motor, which runs very well. the previous owner had replaced both belts and prolly used a size too small for the drive belt, and turned the transmission belt in the wrong direction. after adjusting tension and turning the transmission belt around i found that the tines were locked, or partially locked up. ok so i tried to remove the tines by pulling the axel pins out, but lo and behold they will turn a bit on the shaft but they will not remove!.. my question,,, is there a hidden retainer that holds the tines on the shaft?. i cannot find any reason for them to remain, but i must have missed something, because they just set there no matter how hard i hammer, and i don't want to damage the tines or the shaft. thanks for your time. john weaver
FYI, parmi was bought out by gardenway many years ago,parts are a bear to find. mostly bearings and engine stuff,the rest is prolly gonna have to be machined!
/ parmi, lazyboy tiller #3
I had the same problem with my tiller tines being hard to remove. I found that the hardened pin had egg shaped and bent the hub. I just kept working the hub back and forth and banging on it with a hammer until it came off. Then I filed the inside of the hub with a rat tailed file and the shaft with a flat file. There is no retaining clip on the shaft.
Also, I am looking for replacement tines for my 1984 tiller. You have any leads? I am the original owner and have almost worn the tines completely out. It has been a heck of a tiller.
Jsh: i don't have any leads at the moment, but i'm looking too, my tines are fine, the tine brackets are torn and rounded out, trying to have em welded but not a lot of hope in that. seems the previous owner was tilling a yard and hit a stump, ripped the tine bracket nearly off one side. Update on my tiller though, i hadda replace the bearings (still available from gardenway) and hadda have a new tineshaft made, i guess prev didn't know you should check the bearings once in a while. As soon as i resolve the tine bracket issue i should be up and running.
/ parmi, lazyboy tiller #5
JSH1958 and podieoe
HI 12027boatman here Im in greenville Oh there is a repair shop that might be able to help you out on some tines for the parmi tiller .The name of the place is fricks sale's the phone number is 1-937-548-3535 good luck ,He should be able to come up with something. good luck 12027boatman
2019 HAULOTTE 5533A PORTABLE ELECTRIC BOOM LIFT (A65056)
2019 HAULOTTE...
BOAT MOTOR (A66738)
BOAT MOTOR (A66738)
2013 FREIGHTLINER CORONADO 122 SD (A67714)
2013 FREIGHTLINER...
2011 WESTERN STAR 4900SA (INOPERABLE) (A67714)
2011 WESTERN STAR...
NEW HOLLAND 110TL LOADER ATTACHMENT (A67714)
NEW HOLLAND 110TL...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A66734)
2025 Kivel 48in...
