Parking with FEL up
   / Parking with FEL up #1
jimmyj
Elite Member
Ontario Canada
Allis Chalmers 616 (Two) and a Kioti CK30 HST with loader and backhoe
So often I see tractors parked with the FEL left in the up position. I don't mean when somebody is just off it for a minute either, I mean at dealerships, in fields, for sale on the side of the road etc.
That seems very risky to me, why take the chance of somebody who is not experienced pulling on a lever and down she comes.
   / Parking with FEL up #2
"risky"...I agree,some fel now have locking controls,and seen some dealers place angle iron piston to frame to stop free fall.
   / Parking with FEL up #3
Angle iron & a long worm type hose clamp around the extended cylinder to hold the angle in place was the standard before doing any work that required the FEL arms to be out of the way when I worked in the construction company shop. Long 4x4 under raised dump truck bodies. Anything else was left down while any maintenace +/or repairs.
   / Parking with FEL up #4
Perhaps they don't know that they are totally liable for any mishap that occurs on their property. and any owner. I think it is called. attractive nuisance. It also has to do with providing safety while someone is on your property.
   / Parking with FEL up #5
And some of the newer FELs have a piece of channel iron permanently attached to the cylinders so it is really easy to lock them extended. I always think of my FEL as a parking brake for level ground, plus the dog won't curl up and go to sleep in the shade of the bucket.....
   / Parking with FEL up #6
My dad was an equipment operator for the local municipality when I was in school. I used to watch my highschool janitors mow the property w/ a rear mounted rotary while having the FEL all the way up so they could 'see' as they mowed. They used to tell me to MYOB when I told them how un-safe they were, property had lots of terraced athletic fields.
Then one day dad picked me up after school and seeing them mowing, he walked into the office and spoke w/ the principal. The janitors never had the FEL all the way up again!
   / Parking with FEL up #7
My BIL is like that with his 60HP Massey. All the way up!! Granted its a light FEL with a small bucket. I normally keep the top of my bucket just below the sight line of the front of the hood on my JD 4300. This way it doesn't even block the factory headlights and I still have a foot of ground clearance under it. My seat switch is history so if need be I can stand up for close manuvering...
   / Parking with FEL up #8
As an attorney, I remember my torts (personal injury) professor using as the perfect example of "negligence" a person leaving a hydraulically lifted bucket in the air. "Easy pickings" or something like that was the term he used.
   / Parking with FEL up #9
NO NO NO
I have an excavator that will lockup everything without the key in and on. STILL DOES NOT MAKE A DIFFERENCE !!! Joints fail, hoses fail, controls fail, e.t.c. Why take a chance on someones health{or life} when all it would take is a couple of seconds to drop the buckets to the ground???????????????????
Dealers to this to show what they've got, I say "whoopy show what you've got when you get a customer."
   / Parking with FEL up #10
i make it a point to lower all hydraulics whenever i leave the tractor. my 18 month old loves to sit on the tractor (when it's off and the key is out) and play with all the levers. and the cats are always looking for a shady place to sleep (like dogs). just too easy for an accident to happen!
since reading this board, i always leave all hydraulics down, even when leaving the tractor just for a few minutes.
i also make sure all hydraulics are "jiggled" on the FEL and backhoe when they are off the tractor so someone climbing on them or bumping the levers can't make them move.
safety first and no bad vibes (or worse) later.....
amp
VERMEER NAVIGATOR S3 D10X15111 DRILL (A51406)
VERMEER NAVIGATOR...
2007 Freightliner Columbia 120 - Class 8, 6x4, Mercedes MBE4000 Diesel (A52748)
2007 Freightliner...
2020 BOBCAT T770 SKID STEER (A51246)
2020 BOBCAT T770...
BUSH WACKER ST-180 ELITE BATWING ROTARY MOWER (A51406)
BUSH WACKER ST-180...
Modine Shop Heater (A51573)
Modine Shop Heater...
JOHN DEERE Q 850 M LOT NUMBER 226 (A53084)
JOHN DEERE Q 850 M...
