Parking Brake Light Stays On
   / Parking Brake Light Stays On #1
JPPhipps
Tennesse
Mahindra 5500 4wd
I was out doing some clearing last weekend, when I noticed the parking brake light was on. The brake was not on, I stopped set the brake, released it again and the light still would not go off. Is there a plug or switch that I could check?
   / Parking Brake Light Stays On #2
yes, there is a switch connected to your brake pedal.
part # 005555542R91
MSRP $6.84
This part could be faulty or it just could be that it's stuck in the "out" position. The part is located next to the underside of the brake pedals and is connected with a small spring. Look around at all the springs and linkages underneath and you'll see it.
4K SAND SEPARATOR (A52472)
4K SAND SEPARATOR...
New Wolverine Skid Steer Hydraulic Breaker (A53002)
New Wolverine Skid...
2017 Freightliner Cascadia 125 Single Axle Sleeper Cab Truck Tractor (A50323)
2017 Freightliner...
2005 Dodge Caravan Van (A51694)
2005 Dodge Caravan...
2005 Toyota Tundra Limited Crew Cab Pickup Truck (A51692)
2005 Toyota Tundra...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
