Parking brake adjustment??
/ Parking brake adjustment?? #1
crabjoe
Ceciltucky, MD
Kioti CK20S HST
Is there a way to adjust the parking brake on a CK20?
Today, I parked on a slope, but when I set the parking brake, it just kept inching down the slope until I put the loader down.
/ Parking brake adjustment?? #2
push down harder on the brake before you lift the parking brake lever. There are several positions that hold brake at different pressures.
Unless your pedal is bottoming out, you may need to take up some slack in your brake adjustment. I believe you should only have about 1 inch freeplay in the pedal for correct adjustment.
Thanks for the info. I'll give it a try. :)
/ Parking brake adjustment?? #4
Not sure if HST, if so, is the HST adjusted properly, if not, that could cause creep.
Thanks Joe Signs!!!
I put my foot into it, then set the brake. It hold on the same slop like a champ!!
7'x12' Trailer (A64127)
7'x12' Trailer...
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
2020 Takeuchi TL8R2 (A64126)
2020 Takeuchi...
2013 Chevrolet 2500 HD (A64127)
2013 Chevrolet...
New Holland 311 Square Baler (A66408)
New Holland 311...
SANY SY50U EXCAVATOR (A63276)
SANY SY50U...
