rd_macgregor
Veteran Member
- Joined
- May 14, 2008
- Messages
- 1,875
- Location
- Prince Edward Island, Canada
- Tractor
- Kioti DK45SC, Kubota B2650
I'm having a problem with the Parker Flat-faced couplings on my grapple rake. I keep the couplings mated to keep them clean when the rake isn't mounted. Last time I went to hook up the grapple rake, it was very difficult to get the couplings on the grapple rake apart. After I did, I couldn't get them hooked up to the tractor's couplings (nor, as it turns out, back to each other). With a little experimentation and prodding, I discovered that the male fitting center plunger (valve?) seems frozen/stuck. I can depress the ring in the female fitting, but the center of the male fitting won't budge (even with some careful hammer application).
This doesn't make sense to me, since I had just separated the fittings a few minutes earlier...which means that center piece in the male fitting WAS depressed, but won't move now. What can cause this stubbornness?? Any suggestions would be welcome (replacing the fitting is my last choice).
Thanks in advance,
Bob
Thanks in advance,
Bob
