Loader Park with FEL Up
   / Park with FEL Up #1
BrunoGA
Jasper, GA
LS XR3037H
Good evening all, first post to the forum and a question for the experienced owner/operator. I just recently purchased my first compact tractor, an LS XJ2025H. So far I love it, seems to be everything I need to manage my seven acres. So the question - to fit the LS into my 12x16 shed, with my JD D170 and a LOT of other stuff, I need to leave the loader arms in an up position (less bucket of course). Is this okay to do? I don't want to damage the hydraulic system. Your advice would be much appreciated.
Thanks to you all, I learn more every day that I read the forum.
   / Park with FEL Up #2
In general, stored energy is a safety hazard. There's stored energy in a raised implement: it can fall. It won't hurt your hydraulics to leave it up. But it will be a safety hazard.
Welcome to TBN! :thumbsup:
   / Park with FEL Up #3
It will leak down anyway so don't park it over something you don't want crushed. The best solution would be to block it up or put it on the ground.
   / Park with FEL Up #4
There's stored energy in the actual weight as well as residual pressure in/on the system. I usually "move" the hydraulics after the machine is turned off to get everything on the ground and in a neutral position. I don't think the system would suffer with some residual pressure on it, but there are kids around here, and a small movement would be enough to pinch little hands and feet. Storing stuff under an unsupported loader will result in some squished stuff sooner or later.
   / Park with FEL Up #5
If you do that, get a piece of C or U channel that just fits over the rod of your cylinder and cut it so it just fits in with the FEL all the way up.
Then when you park it, you put it over the extended rod of your lift cylinder and lower the bucket until the weight is resting on the brace.
Aaron Z
   / Park with FEL Up #6
I support my loader with the bucket in the up position also and use a piece of angle iron placed over the cylinder.
But a word of caution is needed here; the end that contacts the cylinder end seal area must not touch the seal and the iron should not touch the chrome cylinder surface to avoid scratches & rust.
I drilled two holes in each end of the angle and placed a zip tie thru the hole so that when the support is in place the nylon zip tie prevents the angle from contacting the cylinder.
When I lower the bucket I do it very slowly with the engine off to avoid forceful damage.
Done it for years with no problems.
90cummins
   / Park with FEL Up #7
90cummins
This sounds like a plan, if you must leave the loader arms up. But as others have pointed out there is still stored energy just waiting for something to happen to change the dynamics. I have always parked my equipment with all loads on the ground, like my 3pt ballast or what ever implement is on at the end of the day and with loader arms down. If you don't pin the arms up in some way, they will slowly lower on their own, and there is no accounting for what children and thoughtless adults will do when you are not around to prevent it.
   / Park with FEL Up #8
All good advice. I'll add one further thing. In addition to the slow leak down while the tractor is sitting undisturbed, if a child or anyone else fiddles around and bumps the joy stick forward, the pressure will release and the FEL will drop. If held forward, or bumped all the way into float position, it will drop all the way, very fast. :eek: Try experimenting with this a bit after you've been parked for awhile. It's a good illustration of how dangerous it is to try to do any work under a raised loader bucket without strong bracing. A very experienced TBN member died recently in an FEL accident while working on his tractor.
   / Park with FEL Up
Great information guys, thank you. I like the idea of putting a brace of some sort (C, U or angle iron) on the cylinder, that should do it. Since it's just my wife and I with no children, and it's in the shed locked up, less chance of danger. But wise advice to be careful around - and not under - the FEL. Again, thanks!
   / Park with FEL Up #10
When I lower the bucket onto the supports all pressure is relieved, I then return the loader control to the neutral hold position.
If the tractor is cold when I bring it into my heated garage after I secure the braces I move the loader control to the float position because it will pick the bucket off the supports when the hydraulic oil warms up and expands.
This happened a couple times until I realized what was happening.
90cummins
2013 FREIGHTLINER EXT CAB SERVICE TRUCK (A51406)
2013 FREIGHTLINER...
2012 Nissan Rogue SUV (A50324)
2012 Nissan Rogue...
Target Ecoline Walk-Behind Concrete Saw (A49461)
Target Ecoline...
71055 (A49346)
71055 (A49346)
2022 CATERPILLAR 259D3 SKID STEER (A51242)
2022 CATERPILLAR...
2023 Diamond Cargo Trailer (A50324)
2023 Diamond Cargo...
