Panel lights
   / Panel lights #1
OhioGuy
Platinum Member
Northeast Ohio
Ford 1220, Case 245, Cub SZ60, Cub 2284
I was using my 1220 today cleaning up some snow and ice and a panel lamp came on. On the 1220 there are four lamps in a row. There were icons on these lenses at one time, they are gone. When I looked in the manual it doesn't say which lamp is which. I believe from left to right are Gen/Temp/Oil Pressure/Glow plug. Now being sure it wasn't the oil pressure light, I put the tractor away. It was the second lamp from the left which I believe is coolant temp. The tractor was not running hot?
Is there a simple test for the oil pressure sending unit and the temp sensor? Seems like I should be able to jumper or open the harness to test.
Thanks, Curt
   / Panel lights #2
Curt,
Just to determine which sending unit is lighting the idiot light, disconnect the ring terminal from the each sending unit and see which one turns off the light.
Both sending units operate by completing the electical path to ground. For the temp sensor, it is a variable resistor. For the oil pressure, it is a normaly closed switch (completing path to ground - light on) that is opened when suficient oil pressure is achieved.
Hope that helps
gorm
   / Panel lights #3
There may be a sensor in the coolant overflow jug. It Indicates the level is low in the jug. Just adding some will make the light go out. I think the jug should be 1/3 to 1/2 full.
   / Panel lights
Thanks for the advice, I'll take a look as soon as it warms up just a bit!
Curt
2016 Ford F-550 4x4 Ext. Cab and Chassis Truck (A50323)
2016 Ford F-550...
John Deere 310A Loader Backhoe (A52384)
John Deere 310A...
2017 Ford 550 XL, Cab and Chassis, Crew Cab (A52384)
2017 Ford 550 XL...
2007 Chevrolet Impala Sedan (A51694)
2007 Chevrolet...
2011 KENWORTH T800 (A52472)
2011 KENWORTH T800...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A52576)
2018 FREIGHTLINER...
