Buying Advice Pallet forks
/ Pallet forks #21
My forks are doing great! Very well made and heavy duty. I use them on about anything I can get a fork under. Have used them a couple times to spear under small stumps and break them loose. No bend or flex. Easy on and off with the ssqa. It is snug, but that's good, no shifting. Probably the heaviest thing I've used them on was a partial pallet of paving stone...guessing 1500-1800lbs. No problem.
/ Pallet forks #22
Thanks for the reply, jdlaw Good to hear, I figure my loader is capable of lifting about 3000 lbs plus, as with my existing grapple weights over 600 lbs and I was able to move 2900 lbs. As these forks are 330 lbs I should have no trouble with 3000#s depending the bulk of the item to be moved. Thanks again
/ Pallet forks #24
I placed an order for a 48 Inch 4400lb Lift Skid Steer Pallet Forks with the help of Travis @ everythingattachments on 10/02/2018 at 01:33PM a Tuesday, I got a call yesterday Tues the 9th that it had arrived I think that is pretty fast to northern Calif. Unfortunately I can't pick it up till Friday I can't wait as I have lots to move could have really used it last few weeks but had to us my grapple forks instead. Big Thanks to Travis for fast shipping.
UNUSED MINI HYD BREAKER (A62130)
UNUSED MINI HYD...
2017 Volvo VNL 760 T/A Sleeper Cab Truck Tractor (A61568)
2017 Volvo VNL 760...
20 Yard Roll Off Dumpster (A61165)
20 Yard Roll Off...
Pallet of Four Pivot Wheels & Tires (A62177)
Pallet of Four...
429136 (A61166)
429136 (A61166)
UNUSED JCT 72" HYD TILLER (A62131)
UNUSED JCT 72" HYD...
