Buying Advice Pallet forks
/ Pallet forks #1
WillBuc59
Alabama
Branson 4225CH, JD870
I’m in the market for some pallet forks and just wondered if there was a certain kind of quick attach i need to be looking for or are they all pretty much the same?
I have a 2018 4225 that has the quick attach bucket.
Some of the “universal” quick attaches I have seen look slightly different where the securing bolt goes through the bottom but they may still be usable with my QA.
/ Pallet forks #3
My Branson dealer had 4000 PFs for my purchasing. Fit my skid steer dimensioned quick hitch FEL on the 6530.
/ Pallet forks #4
I would expect that you have SSQA, they will have a pair of tapered pins that engage a slot in the lower edge,
the only ones with "bolts" or pins would be JD,
then their is the Global quick attach on larger equipemt.
/ Pallet forks #5
The pallet forks I got from Titan (palletforks.com) fit my 3725's quick attach well.
/ Pallet forks
I believe you are right, SSQA is what I have.
/ Pallet forks #7
The John Deere QA:
Global Carrier:
SSQA:
/ Pallet forks #8
Good pics of the various quick attach,
I prefer the global they seem easier to reconnect,
and safer to disconnect.
The global on the Puma and 5070 have a catch when you unlatch,
after you catch the top hooks and rotate up when the lower pins lineup the latches engage automatically.
One time disconnecting I unlatched the ssqa with the bucket tipped down, just reached over the bucket and unlatched
it fell off and almost got my toes.
The globals upper hooks stay engaged till you lower down out of them.
/ Pallet forks
In the ssqa drawing the bottom piece where the locking pin goes thru, has two holes on each side. My Branson QA bucket has only one slot on each side. Hopefully they’ll line up with the titan forks I ordered
/ Pallet forks #10
I recently got some palletforks.com forks (Titan). One of the holes was a bit tight and I had to grind it a bit so that the pin on my tractor (Branson 3520h) would engage. All I had was a 4" grinder but it managed; had to take about 3/16" off as the pin was barely poking in the hole before and obviously wouldn't lock.
I haven't put any other FEL attachments on yet so I can't say if there's something funky about my tractor's pins or not - I suspect not as the my OEM bucket fits perfectly.
2022 John Deere R4023 (A60462)
2022 John Deere...
Iranch IRET13 (A60463)
2025 Hydraulic Trencher Skid Steer Attachment (A61567)
2025 Hydraulic...
2012 ALTERFER  CAT GENERATOR (A60736)
2012 ALTERFER CAT...
Forward 10,000lb Two-Post Electric Auto Lift (A55851)
Forward 10,000lb...
2023 Chevrolet Express Van, VIN # 1GCWGBFP8P1104620 (A61165)
2023 Chevrolet...
