Loader Pallet forks
/ Pallet forks #1
JohnDeere391
Connecticut
JD 4500
Are they worth it? I have found a set 36in 4500 lbs capacity for 500$? Good deal??? I will be using them for unloading pallets, moving logs and picking up 2000lbs blocks.
/ Pallet forks #2
My bucket is parked. Forks stay on. Should have been the first thing I bought
/ Pallet forks #3
Get a set of 48". You'll be glad you did. That way you can go at pallets from both ends
/ Pallet forks #4
I am constantly using my 48" forks for something. They will lift LOTS MORE than pallets
/ Pallet forks #5
first off, find the lift capacity of your loader, subtract the weight of the pallet forks, thats what youll be able to lift. The heavier your forks, the less youll be able to lift.
/ Pallet forks #7
/ Pallet forks #9
Then the last 2 links is what you want..
/ Pallet forks #10
I've used forks on my previous 2 tractors (4115 & 1026r) and now with my 3320. Besides things on pallets, I have moved logs, large rocks, piles & piles of brush, mowing decks, truck caps, picnic tables at different social clubs (30+ tables), unloaded trailers & trucks, moved deck furniture onto and off deck, lifted wooden bed off hay wagon to fix axle, etc., etc.. I made 8' wood extensions for the 1st set of forks for moving light stuff, and just recently made an 8' aluminum set from an old swimming pool top rail to move my truck cap. My Horst 2000lb set fit the loader frame perfectly.
Highly recommended!
2015 John Deere 5055E (A64126)
2015 John Deere...
TEST YOUR BID BUTTON! (A65053)
TEST YOUR BID...
2015 Volvo L30GS (A62180)
2015 Volvo L30GS...
Skid Steer Trencher (A65640)
Skid Steer...
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
New/Unused CFG Industrial NT18K Mini Excavator (A65583)
New/Unused CFG...
