Forks Pallet Forks for Rhino 2049
   / Pallet Forks for Rhino 2049 #1
sheetsg
Bangor, PA
DK45
I'm working a deal to get a Kioti DK45 with KL2049 FEL. I'd also like to get pallet forks to off load 1 ton pallets (horse supplies & such) too. I don't think I need the quick attach plate, so is there a pallet fork available to replace my bucket?
   / Pallet Forks for Rhino 2049 #2
Little Tractor has them in light and heavy models
   / Pallet Forks for Rhino 2049 #3
Picture is of a Woods small loader pallet forks model 20A on a JD 790 tractor
For more infor see PHOTO forum titled "Testing New Pallet Forks.
Does this pallet fork attach by removing four pins to the bucket or does it use some other means?
   / Pallet Forks for Rhino 2049 #5
I have a standard hook up, the pallet fork go on just like the loader bucket, using four pins....
The brackets are adjustable for different widths an come drilled for different pin sizes...
I've found far more use for the pallet forks then the bucket.
   / Pallet Forks for Rhino 2049 #6
Hi
i have a DK 50 with FEL . i atatch forks at times and there i no way i could lift 1 ton. Once more the FEL is not rated to do so i think off my head about 500kg is all.
see the deeres behind
2011 4300M7 International (Pavo, GA) (A50123)
2011 4300M7...
2004 FREIGHTLINER FL70 FLATBED W/TANK & DITCH WITCH MIXER (A55745)
2004 FREIGHTLINER...
AIR COMPRESSOR (A55745)
AIR COMPRESSOR...
LayMor Sweepmaster 300 8HC (A55314)
LayMor Sweepmaster...
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
2017 Mack GU713 Granite Tri-Axle Dump Truck (A51692)
2017 Mack GU713...
