Pallet Forks for KL401
   / Pallet Forks for KL401 #1
mark.r
Platinum Member
Leesburg, VA
Kioti DK45SE
Does anyone have a line on pallet forks that fit the Q-tach set up on the KL401 loader? Calling Mr. Wallace . . . Rick, do you carry any?
crabjoe said:
Not sure if these will work or even if these give you the capacity you want. But Take a look at these. COMPACT X-TREME DUTY Shaft Mounted Pallet Fork
There's a distributor in NC selling them for $550, shipped.
I believe those will work. I found another site that has pictures of the mounting plate. Altough these pictures show what looks to be a Montana which is using the two level Kubota type Qtach system, I would think the Kioti KL401 single lever system would work as well. I believe the pins still lock in the same way. Can anyone comment for sure.
The weight limit for these is 1800lbs. which is not too bad. I am going to be using them for moving around a water tank they we use to fill water troughs that we don't have hose access to. The tank is a 275 gallon unit so I wouldn't be able to fill it completely as that would put me over the weight limit. But to be honest I don't need me than a 100-150 gallons each time I run it out to the pasture.
   / Pallet Forks for KL401 #4
You might want to check out Horning Pallet Forks sold in four different locations here in Pa. They look a bit more substantial than the ones you have pictured. I've had one on my DK 45 for a year and it's worked well. They are $580.
Will do. I am open to any brand. I am more concerned with the Qtach fitment. I believe you "S" fitment is different than the "SE", 2 lever vs. 1 lever. Is the mounting plate still the same?
Do you have any dealer links/names for the Horning Pallet Forks?
   / Pallet Forks for KL401 #8
Mark
You quick tach set up will work with any brand skid steer style quick tach set up.
The only thing is when you put the quick tach forks on just make sure you are centered in the quick tach plate to allow you retainer pins to drop in.
   / Pallet Forks for KL401 #9
Do you have any dealer links/names for the Horning Pallet Forks?[/quote]
Melvin Martin----814-793-4199Reinford Farms--814-275-3033Merv Horning----570-966-1025Weaco Equip.----610-589-5555Hope this helps.
Melvin Martin----814-793-4199Reinford Farms--814-275-3033Merv Horning----570-966-1025Weaco Equip.----610-589-5555Hope this helps.[/QUOTE]
I was trying to find a picture of the Horning Forks. I found these on the Weaco site. Do these look like them?
2018 Taylor-Dunn BigFoot B5-440-36 Electric Utility Cart (A50322)
2018 Taylor-Dunn...
2016 Nissan Murano SL AWD SUV (A50324)
2016 Nissan Murano...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
110 gal Sprayer Tank (A50514)
110 gal Sprayer...
2018 John Deere 470G Hydraulic Excavator (A50322)
2018 John Deere...
