Forks Pallet forks for a 3 pt hitch?
   / Pallet forks for a 3 pt hitch? #1
slate mike
I have a JD 3120 and I need to move pallets of wood pellets. Each pallet weighs 1 ton. According to a friend who also has a 3120, his FEL with JD forks will not pick up 1 ton. I have only used my tractor for fel work, plowing and mowing and have no idea if the 3 pt hitch is capable of picking up a ton or if forks for this purpose even exist. Thanks in advance for any info or suggestions.:confused:
   / Pallet forks for a 3 pt hitch? #2
The 3120 3pt maxes out about 2200-2500 lbs. It'll be close.
Which FEL comes with the 3120 ?
   / Pallet forks for a 3 pt hitch? #3
I dug up the specs on both possible loaders on the 3120.
I believe your stuck with the 3pt on this one.
FEL is 300CX.
2018 MACK CHU613 DAYCAB (INOPERABLE) (A55745)
2018 MACK CHU613...
FUEL TANK W/2 STANDS (A55745)
FUEL TANK W/2...
2011 FORD F-550 (INOPERABLE) (A55745)
2011 FORD F-550...
JOHN DEERE 7210R TRACTOR (A51247)
JOHN DEERE 7210R...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A55302)
Kubota SVL65-2...
2006 V.E. ENTERPRISES 130 BBL STEEL VACUUM TRAILER (A53843)
2006 V.E...
