Forks Pallet forks for a 3 pt hitch?
   / Pallet forks for a 3 pt hitch? #1
slate mike
I have a JD 3120 and I need to move pallets of wood pellets. Each pallet weighs 1 ton. According to a friend who also has a 3120, his FEL with JD forks will not pick up 1 ton. I have only used my tractor for fel work, plowing and mowing and have no idea if the 3 pt hitch is capable of picking up a ton or if forks for this purpose even exist. Thanks in advance for any info or suggestions.:confused:
   / Pallet forks for a 3 pt hitch? #2
The 3120 3pt maxes out about 2200-2500 lbs. It'll be close.
Which FEL comes with the 3120 ?
   / Pallet forks for a 3 pt hitch? #3
I dug up the specs on both possible loaders on the 3120.
I believe your stuck with the 3pt on this one.
FEL is 300CX.
UNUSED FUTURE 32" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 32"...
2013 Freightliner M2 106 Altec AA755 55ft Bucket Truck (A55852)
2013 Freightliner...
2015 Ford F-250 Ext. Cab 4x4 Flatbed Truck (A53422)
2015 Ford F-250...
Redirective Crash Cushion Guardrail (A55852)
Redirective Crash...
2007 Ingersoll Rand P185WJD Towable Diesel Air Compressor (A52377)
2007 Ingersoll...
2006 V.E. ENTERPRISES 130 BBL STEEL VACUUM TRAILER (A55745)
2006 V.E...
