Forks pallet forks for 3pt hitch???
   / pallet forks for 3pt hitch??? #11
I found the same thing as Bob. They are available, but expensive. I built these. I got smart very quick and had a hydraulic top link first, then a Speeco quick hitch.
My first model was for 3pt only. (Np loader yet.) After the loader came I adapted the forks to fit both loader or 3pt. Because there is a quick hitch front and rear it is very easy to install.
Forks were used, almost new. First time out with this I put it under a big oil field tank. It picked the front tractor tires off the ground before the tank would budge. Be sure to get real forks, not something you weld up from channel, etc. The metalurgy in real forks is different and if sized right and not abbused they are almost impossible to bend.
   / pallet forks for 3pt hitch??? #12
This shows the forks after modified for the FEL. There is a brush rake slipped on the forks in this photo.
   / pallet forks for 3pt hitch??? #14
The only problem with the carry-all's is their construction limits the load to about 600-800 lbs even with the extra brace on the back end. That is only about half the capacity of the typical CUT 3pt.
   / pallet forks for 3pt hitch??? #15
Tom . . . The carry-all units are really nice & easy solutions for light duty applications but they really don't have the capacity to haul pallets of wood or other heavy loads. The carry-alls make great platforms for many projects, and can serve as a pallet lifter in a pinch, but even a reinforced pallet lifter won't come close to lifiting the capacity of what most small or medium tractors are capable of lifting.
They certainly are a viable option for lighter duty tasks.
   / pallet forks for 3pt hitch??? #16
MadReferee and Bob,
I am aware of the limitations of carry-alls. The original poster stated that he "needed to transport materials" on this 3ph. He did not state weight or price ranges. Others replies discussed 3ph pallet forks only. If lower price is a concern, or if he only needs to transport lower weight materials, then a carry-all is a viable option for him. Since no one else had mentioned it, I thought, and still think, it is reasonable for me to bring it to his attention as a possible option.
   / pallet forks for 3pt hitch??? #17
Here's a set I fabbed up from recycled steel parts.
The forks were from a machinery auction.
Agree with all comments here that hydraulic top link is a must with 3-pt forks.
CASE 586E ALL TERRAIN FORKLIFT (A55745)
CASE 586E ALL...
2020 PETRBILT 567 SLEEPER TRUCK (A56138)
2020 PETRBILT 567...
2005 Chrysler Town and Country Limited Van (A55853)
2005 Chrysler Town...
2023 FORD TRANSIT VAN (A52576)
2023 FORD TRANSIT...
2430 (A51248)
2430 (A51248)
