Pallet forks extension for hauling brush?
   / Pallet forks extension for hauling brush? #1
Tippmann98
West Salem
iH 1486
Has anyone made something for their pallet forks to haul/push big piles of brush? I am not talking just slip on extensions, but maybe something that makes the entire frame 6-8ft wide with the forks spaced 6-8ft too?
   / Pallet forks extension for hauling brush? #2
Saw a photo where a farm gate or a section of temporary fence was used. They were hauling leaves.
   / Pallet forks extension for hauling brush? #3
If you use something like a cattle gate or a livestock pen section, and pushing small items to line the heavy frame with a lighter (but not to light) fence or a pig panel/something that the debris will not rip apart but small enough openings that the debris will not come through and damage your tractor (I have seen limbs puncture radiators). If you can handle the weight of a cattle gate and expanded mesh metal, that would be ideal in my opinion.
Weld in a couple of slots for your forks to slide into and use a chain and binder to secure it to the fork frame and start pushing.
   / Pallet forks extension for hauling brush? #4
I did this. They are easy to clamp on to my forks.
   / Pallet forks extension for hauling brush? #5
Hay fork or sweep. :)
Some older still photos at about 2:32
Better view of the sweep
YouTube
Bruce
   / Pallet forks extension for hauling brush? #6
Or, hire her!
Good suggestions guys! Thanks a lot. Got the wheels turning in my head now
   / Pallet forks extension for hauling brush? #8
Post pics of your solution.
   / Pallet forks extension for hauling brush? #9
I haul a lot of brush with my pallet fork extensions and just never hardly drop anything if I stack it right. Sometimes I use my manure forks but my home made extensions that slip on the forks allow me to haul one heck of a pile. Only problem is seeing over and around it.
   / Pallet forks extension for hauling brush? #10
Yep, same problem with the 54 inch wide, 4 foot long brush fork:
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
2006 Ford Fusion SE Sedan (A51694)
2006 Ford Fusion...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52576)
2016 FREIGHTLINER...
2012 UNVERFERTH 6-INCH FRONT WHEEL SPACER KIT FOR 10 BOLT HUB (A52748)
2012 UNVERFERTH...
2015 TIGER MANUFACTURING  10"X12" PUMP (A52472)
2015 TIGER...
2008 Hino 268 Truck, VIN # 5PVNJ8JV582S51513 (A51572)
2008 Hino 268...
