Buying Advice Pallet fork recommendations?
   / Pallet fork recommendations? #1
wtfgreen
Hello everyone.
I just got my first tractor, a new CT235, and one of the attachments I want to get ASAP is a good set of pallet forks.
I have roughly 18 acres of woods I need to do some maintenance in, and would like to use the forks to stack logs for cutting/drying, move a wood hopper around in winter, as well as place heavy items in racks when not in use - snowmobile in the summer for instance.
Wondering what people suggest as the best set of forks for the money?
Thanks!!
JG
   / Pallet fork recommendations? #2
   / Pallet fork recommendations? #4
I bought a set of skid steer forks off of craigslist for $300 but they are really too heavy for my CT230. I would go with something as light as you can find that can withstand your loader ratings so you don't loose a lot of lift capacity.
It seems like when I was looking I found a set of 2000lb forks on eBay, I don't remember the name of the place but you might try searching there in addition to what k0ua gave you.
   / Pallet fork recommendations? #5
Don't buy a full sized 4000lb set of skidsteer forks but don't get bucket forks either. 42 inch light duty 2000lb capacity quick attach forks would be a good match for your loader lift capabilities.
The ones recommended above from construction attachments look fine though I am surprised at the price as you can get a full sized set for not much more. Might be worth checking eBay too.
   / Pallet fork recommendations? #6
I kept hunting for a used set but only found forks that were to big and heavy for my CK30hst(CT230 kin). I finally bought the EA ones mentioned by K0ua. They're listed as weighing 220lbs with a capacity of 1800lbs. They seem lighter than 220 if I move them around by hand. As Island mentioned, a 2400lb set isn't that much more but it's overkill and adding more weight for our smaller loader capacity. Mine work well for what the loader can handle.
   / Pallet fork recommendations? #8
Bobcat offers a set of lighter wieght forks specificly for the tractor, don't weigh nearly as much as skid-laoder forks. Price is is same ball park as Everything Attachemnts.
   / Pallet fork recommendations? #9
If you're capable of making your own, get a set of forks & rails from atvexpress on ebay! ~~ grnspot
   / Pallet fork recommendations? #10
I bought at set of 48 inch forks and use the extra 6 inches often when moving things. When carrying full pallets they go all the way through and limit stacking some but when used for logs are helpful.
just food for thought
2019 MMDI 14ft T/A Utility Trailer w/ Fuel Tank (A48082)
2019 MMDI 14ft T/A...
TC710 FINISHING MOWER (A50459)
TC710 FINISHING...
2018 Ford F-150 (A51039)
2018 Ford F-150...
1986 ASPT 30ft S/A Pole Trailer (A49346)
1986 ASPT 30ft S/A...
2004 TRAILKING 101" X 53' STEP DECK TRAILER (A50459)
2004 TRAILKING...
2014 UTILITY 53X102 DRY VAN TRAILER (A50046)
2014 UTILITY...
