Pallet Fork Grapple
/ Pallet Fork Grapple #1
PCABE5
Platinum Member
Wisconsin
John Deere 4066R Cab and loader
Any of you have a pallet fork grapple? If so what brand and what do you think of it?
I'm looking at one myself and I'd like to see what others think of them.
/ Pallet Fork Grapple #2
I mounted a thumb on my Titan Pallet Forks, it works pretty good, not nearly as good as a grapple would, but it gets the job done!
If I could do it over I would buy just the pallet forks and put the extra money towards a grapple. If you need forks and can only buy one attachment then get the pallet fork grapple!
Thanks Underdog. I have a set of pallet forks and they are one of the best attachments IMO. One of my uses is I use them for occasional tree and brush cleanup and my thought would be adding this to my pallet forks would cut down some time for me. I don't really have a need for a full grapple but this may be a good compromise and expanding the use of the forks.
/ Pallet Fork Grapple #4
My pallet forks with single matching grapple is my best buy.
I like the single grapple better, because I can slide my forks closer together to pick up medium sized rocks and for other jobs where I need the forks together.
I've used a dedicated grapple a lot in the past and there's nothing my pallet forks/grapple won't do that the grapple can, and on top of that, the pallet forks will do a LOT more than a dedicated grapple.
I've probably posted a hundred pictures in the past, proving it. Mine is ALO brand...
SR
Thanks SR. I'll search for some of your pictures.
/ Pallet Fork Grapple #6
My firewood totes are 6 ft high so a fork/grapple set up will not work. I am stuck using two different attachments. If you do not need to every carry a tall pallet load a combined unit makes a lot of sense.
The one I'm looking at comes completely off with two bolts in the matter of a few minutes for that reason. Probably could put it on and off in less than 5 minutes.
/ Pallet Fork Grapple #9
Very interesting thread. I wasn’t aware a “pallet grapple” existed. I have a set of pallet forks on order from EA. I also had the 3rd function installed on my new tractor in anticipation of a grapple one day. I’m honestly not sure how much use I have for a grapple but think they are awesome. Put putting a thumb on pallet forks seems like a win-win!! Do you guys have a link where these are available to buy? Recommendations? I’ll be in research mode now.
/ Pallet Fork Grapple #11
That thing just gets in the way, when you need the folks closer together...
It sets too far forward too...
SR
/ Pallet Fork Grapple #12
This is what most people use over here. Mostly smaller loggers that can't justify a trailer with a logging crane, so they just use one of these on the loader.
Lonestar Panel 24ft. Free Standing Panel with Feed Bunk (A65640)
Lonestar Panel...
2020 KUBOTA SVL75-2 TRACK LOADER (A59914)
2020 KUBOTA...
72in Blue Diamond Grapple Bucket (A65579)
72in Blue Diamond...
New/Unused 76in Pallet Fork Extensions (A65583)
New/Unused 76in...
New/Unused 76in...
2014 Honda Accord Coupe (A61574)
2014 Honda Accord...
