Palatine, IL
   / Palatine, IL #1
tdg54
Palatine, IL
Cub Cadet LT1018
Just found this site whilst looking for info on a broken Tie rod. Who knows, maybe this is something I can DIM (Do it myself) and fix.
   / Palatine, IL #2
They are easy to replace. You could look on you tube. Could you post a picture of the broken one?
Basically, you loosen the castle nut on top. The stud which the nit is on is tapered into the spindle. Use a hammer to tap on the area of the spindle in which the taper is set. This is the hardest part. Once you get that separated mark the threads where the end is unscrew the body of the ball joint. Screw in the new one and then place the taper into the spindle. Tighten the castle nut, put in the cotter pin and you are done.
2016 FORD F250 XL SUPER DUTY TRUCK (A51406)
2016 FORD F250 XL...
2007 FORD F750 XLT SUPER DUTY SERVICE TRUCK (A51406)
2007 FORD F750 XLT...
2022 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A55788)
2022 Chevrolet...
UNUSED (1) 3500# AXLE W/ BRAKES (A54756)
UNUSED (1) 3500#...
2016 Ford Taurus AWD Sedan (A55758)
2016 Ford Taurus...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
