Painting stack valve
   / Painting stack valve #1
canoetrpr
Veteran Member
Ontario, Canada
Kubota M7040 cab/hyd shuttle - current, Kubota L3400 - traded
When I was mucking around looking for a good location to mount my Prince SV stack valave, my wife who was helping me, was wondering whether or not I'd be painting the valve to match the tractor.
I couldn't give her a good reason as to why the valve couldn't be painted but I thought I'd check here just in case.
Once the tierods have been torqued, should I still be worried that if I used spray paint on it after covering essential areas like the ports, inputs, outputs etc., that some paint would get into the work sections?
   / Painting stack valve #2
Go-ahead and paint it, if paint can get in then you have a bigger problem of oil getting out!
   / Painting stack valve #3
Yeah, Kenny is right. Go ahead and paint it.
I paint mine before I install it. I use pipe plugs in the ports and tape off the chrome plunger(s) for the handle.
Thanks for all the help gents. My valve came with plastic plugs in all the ports so I figure I'm covered once I use masking tape on the plunger handles.
I've just gotta pick - Kubota orange or ROPS grey :)
2018 Ford Transit 250 Cargo Van (A51692)
2018 Ford Transit...
New/Unused CFG Industrial MH12RX Mini Excavator (A51573)
New/Unused CFG...
2009 INTERNATIONAL PRO STAR (A52472)
2009 INTERNATIONAL...
2024 BRAZOS 53FT ALUMINUM STEP DECK (A52472)
2024 BRAZOS 53FT...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2019 FREIGHTLINER...
2007 International 7600 Tandem Truck, VIN # 1HSWYAHR37J478209 (A51572)
2007 International...
