Painting rim
/ Painting rim #1
mayer2323
I have my tire off my rear rim and inside there is some surface rust . i going to sand it and paint . I was going to use rustolem or are there better products, also the outside too.
/ Painting rim #2
I would remove all rust, dirt, loose paint, etc.. on areas that had rust previously I would brush on a coat of Must For Rust and then use a couple of good coats of Rustoleum primer, then Rustoleum paint as a top coat. Rust remover
Another option: I have had good luck with POR15 for a super tough finish on tractor rims. -POR-15 Inc.
/ Painting rim #3
Another recommendation for POR 15!!. WOrks great. Tough paint.
/ Painting rim #4
POR 15 has a reputation for chemically bonding w/ rust to stop it. It is expensive and it works. Internal rim corrosion will eventually ruin the rim from the inside out so dealing with this is the right thing to do.
/ Painting rim #5
Ditto what the others said.. mechanically remove as much rust as possible. then chemically convert the rest. then paint it to seal it.
I like epoxy piants inside rims for superior water adn scratch reistance.. keep it sealed and it's hard to rust.. etc.
soundguy
2018 PJ Trailers 14ft T/A End Dump Trailer (A61568)
2018 PJ Trailers...
2025 LandHonor DH-22-84W Disc Harrow Attachment (A60353)
2025 LandHonor...
2018 GENIE GS-2632 ELECTRIC SCISSOR LIFT (A62129)
2018 GENIE GS-2632...
GENIE GS-1930 ELECTRIC SCISSOR LIFT (A62129)
GENIE GS-1930...
UNUSED GIYI 29" MINI HYD SIDE SHIFT PALLET FORKS (A62130)
UNUSED GIYI 29"...
2013 John Deere 848H (A61166)
2013 John Deere...
