painting dirt scoop
/ painting dirt scoop #1
wilsonfarm09
graham nc.
massef fergson grah
can anyone tell me what to paint a dirt scoop with . brand of primer and paint that is compatlble that wil take hard use
/ painting dirt scoop #2
Best choice in my opinion would be powder coating. Anything you can spray at home will have a short life span in dirt.
Powder coat will fail also, it'll just take longer to fail.
Ken
/ painting dirt scoop #3
It depends on how much you want to spend. I have had good luck with POR-15, which is "Paint Over Rust". You don't have to get to bare metal or prime, you just have to get to an intact (not scaling) surface. It cures by exposure to moisture, and it gets very hard. There are a few drawbacks. It's expensive. It's messy to work with- do not get it on your hands, it is tough to get off. Because it's moisture cured, once you open the care you're committed. The instructions say it should be top coated for UV protection.
I had the repair shop paint the loader arms on my CTL with it after they rewelded them. My CTL worked in the cement business before I bought it, and that tore up the steel. The shop that rewelded the arms didn't have the facilities to do much finish work, but I did get them to rough up the rusty steel and coat it with POR. They used a spray can for the top coat. It looked pretty good when they were finished with it, and it has held up to heavy use for a year now.
/ painting dirt scoop #4
I second the POR paint. Just heed LWG's warnings, well put. It isn't the prettiest final product but I found it to be very durable.
2022 EZ-GO ELITE...
213086 (A64276)
213086 (A64276)
2011 GALYEAN 130BBL (A65643)
2011 GALYEAN...
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
3145 (A63117)
3145 (A63117)
1997 MACK MIXER (A65643)
1997 MACK MIXER...
