Painting Aluminum Siding
   / Painting Aluminum Siding #1
Worksmart
S.E. Michigan
L6060, BX22, 1953 Farmall Super A, 1949 Farmall Cub, 1964 International Cub, 1966 International Cub, 1976 International Cub
Good Morning All - I know painting aluminum siding is a bit tricky and can fail quickly if it's not prepped correctly. What is the PROPER way to prep it for paint? Is there some kind of cleaning/etching product to help with the adhesion of the paint to the aluminum? Thanks C
   / Painting Aluminum Siding #2
Worksmart, there are aluminum primers available if you have new aluminum. If it's older aluminum that has been painted in the past, according to what I've read, and a paint dealer told me, the old paint is a good primer if it's clean. About 15 years ago, my parents had an old mobile home down at the coast that was looking bad, and I just scrubbed it down with one of those revolving brushes on the end of a wand hooked to a garden hose. Then I sprayed it, using a Wagner power painter, with latex paint made for aluminum; still looked pretty good 8 years later; haven't seen it since then.
   / Painting Aluminum Siding #3
Worksmart....I can't believe you posted that question/w3tcompact/icons/shocked.gif I was just getting ready to ask the same thing. That's wierd, well thanks for the input Bird. Mine was factory painted.
   / Painting Aluminum Siding #4
The biggest thing is to have it clean, the old paint starts to chalk which doesn't allow the new paint to stick. We use a 3000 psi pressure washer to wash them down, it does a great job of removing the chalk and cleaning any other dirt off of the siding making a nice surface for the paint.
Thanks all. I figured a good power washing/cleaning was a necessity. I'll check for a specific primer for aluminum, Bird. Just curious, is it some type of etching primer? I would think any type of "bite" the paint can get will help the durability. C
2017 TAKEUCHI TS50V SKID STEER (A52706)
2017 TAKEUCHI...
2019 John Deere 1025R Tractor (A52377)
2019 John Deere...
2012 International 4300 Vacuum Excavation 7.6L Diesel Truck w/Vanair Vacuum (A51692)
2012 International...
1837 (A51248)
1837 (A51248)
Peterbilt National Crane Series 900A 26 Ton Tri-axle Crane Truck (A52377)
Peterbilt National...
Oster Pipe Threading Machine (A51695)
Oster Pipe...
