Paint your hoses
/ Paint your hoses #1
Laneman
Here's a tip I learned: The outer covering of hydraulic hoses cracks due to sun exposure. Water base exterior house paint provides 100% UV protection. Not sure if oil base paint does as well, but I know water based does. When I painted my loader I painted all of the hoses, albeit with oil base. I think they will hold up just as well.
/ Paint your hoses #2
I wouldnt use any airsol paints as the propellant is typically not rubber friendly. I would also worry about cracking of the paint over time at the areas which flex. Why not use hose sleeves? those will also help against abraision and is fairly inexpensive.
/ Paint your hoses #3
Maybe I should have painted my trailer tires when I replaced them, not just the rims.....They are 5 years old and look worse for cracks than the 20yr old Goodyears that I took off!!!
/ Paint your hoses #4
Planned obsolescence on modern rubber.
larry
/ Paint your hoses #5
If you're going to do this, it is probably a good idea to make note of the layline on your hoses and write it down somewhere. As someone in the hose business, I get phone calls very often from people wanted us to make replacement hoses for them, and they have no idea what hoses they have on their equipment now, or what kind of pressure the replacement hoses must handle.
2 Row Cultivator (A64047)
2 Row Cultivator...
2022 EZ-GO ELITE...
Chariot Scrub 20 Electric Floor Scrubber (A64194)
Chariot Scrub 20...
2020 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2020 INTERNATIONAL...
2021 CATERPILLAR 320 EXCAVATOR (A65053)
2021 CATERPILLAR...
INDUSTRIAS AMERICA 2426 - 10' OFFSET DISC HARROW (A64277)
INDUSTRIAS AMERICA...
