Paint on Hydraulic Cylinder
   / Paint on Hydraulic Cylinder #1
CurlyDave
Elite Member
Grants Pass, OR
JD TLB 110
OK guys, I need some help here.
I installed a thumb on my JD 110 last weekend, and when the welder finished welding the mounting plate on the dipperstick, he spray painted it with primer. Then I spray painted the while thing with JD yellow, and managed to get specs of overspray on the chromed rod which extends from the hydraulic cylinder.
No, I didn't paint the whole thing yellow, I just got overspray on it. If I needed to describe it better, I would say hold up an ordinary windowscreen and there would be about one small paint spec in each square of the mesh.
Should I try to get it off, or just leave it?
How do I get it off? A paint stripper (might deteriorate the o-rings in the cylinder)? Automotive polishing compound might leave fine grit in the o-rings)? Scrub the cylinder with a Scotchbrite pad (this might be good, the chrome plating is very hard)?
Does anyone know for sure?
   / Paint on Hydraulic Cylinder #2
Paint thinner should do just fine. No chance of hurting the shaft or seal using this method.
   / Paint on Hydraulic Cylinder #3
Mineral spirits (paint thinner) probably would work. Put a little on a rag and rub. The paint should come right off.
   / Paint on Hydraulic Cylinder #4
If plain ol' paint thinner doesn't get it off, try "brake cleaner" or carb cleaner. If you're worried about residue from either of those eating at rubber seals, clean again with contact cleaner (which may well remove the paint on it's own) All three of these products will evaporate and leave the ram clean. If you don't use it right away, shoot some WD-40 or rub it with some hydraulic oil to prevent any surface rust after cleaning.
   / Paint on Hydraulic Cylinder #5
Lacquer thinner on a rag will take it right off, don't ask me how I know that. We always keep a quart of the stuff around for cleanups.
Extend the cylinder before clean-up so you stay away from the seal.
   / Paint on Hydraulic Cylinder #8
Ditto.. scotch brite or a kitchen plastic scrubbie and paint thinner...
paint in the hyds are way worse that a small bit of wear and tear on the chrome rod.. or the outter surface of the piston 'wipe'
I always put a band of tape around my piston rod at the wipe, and then run a good hadfull of grease all over the rod.. whipe clean after painting.. remove tape.. no issues..
Soundguy
Well, it actually came off with nothing but a paper towel.
The ram had a thin layer of oil on it and the paint just plain didn't stick.
   / Paint on Hydraulic Cylinder #10
Good deal. Usually frequently used hyd pistons are like that.. enough oil to keep overspray off. it is when they set a while that they get dry.
Soundguy
NPK GH-7 Excavator Hammer (A50774)
NPK GH-7 Excavator...
CFG Industrial MX12RX (A50121)
CFG Industrial...
2013 Chevrolet Cruze Sedan (A50324)
2013 Chevrolet...
2012 Cadillac SRX SUV (A50324)
2012 Cadillac SRX...
2017 JLG Skytrak 6036 6,000LB 4x4 Rough Terrain Telehandler (A50322)
2017 JLG Skytrak...
International 284 Tractor (RUNS) (A50774)
International 284...
