Padlocks
   / Padlocks #1
quicksandfarmer
Elite Member
Coastal Rhode Island
Jinma 354, purchased 2007
I have four gates and three barns that I like to keep locked. I'm thinking of getting a new set of locks and I'm curious what everyone likes. I've had problems with lightly-used locks seizing up with time. I've tried various keyed-alike locks, which are handy, but I can't match the ones I have any more.
Thanks.
   / Padlocks #2
We use master locks at work (with a whole bunch of locks). When you get them, the keys have a lock number on them and you can order more locks with the same number.
As for keeping them freed up, the only way to do that is to exercise them and hose them down with some kind of lubricant. As I recall, we use something like white lithium grease on them every few months.
Aaron Z
   / Padlocks #3
I like the powdered graphite that goes in as a dust. It won't get gummy.
When I started here in 2001 there were a dozen unlike locks on doors, cabinets, tools. You needed to take along a big ring of keys like a jailer to get anything open.
I bought a dozen S Parker 'Jaws' padlocks all keyed alike. Very reasonable price via Ebay.
S. Parker's website: Padlocks
Nearly all the padlocks have outdoor weather exposure, and the fog here has salt from the ocean 10 miles west. In near 20 years these locks have been fine, with a little maintenance - the graphite powder. This model lock isn't huge and I don't know how pick-resistant it is, don't know if I would use it in the city with sophisticated burglars. In my use, the mounting location would give way before the lock itself. Out here where pilferage of tools etc would be the greatest hazard, they have been ideal.
   / Padlocks #4
Any padlock exposed to the weather will get moisture inside either from rain or from humidity and condensation. The best "weatherproofing" I have seen is definitely low tech--a flap of old inner tube nailed to the door or gate above the hasp. The flap should be generous enough to allow some air circulation as well as access to operate the lock but secure enough not to be blown aside by storm winds.
As Aaron Z said, exercise and lubrication are necessary.
   / Padlocks #5
I agree with Capt dirt. We need to cover the locks here or they freeze over the course of winter. We still need to keep them oiled and we use Super Lube 51004 Synthetic Oil with PTFE and do that yearly. And better locks do work better, last longer and must have more brass and stainless parts in them.
   / Padlocks #6
I’d hit up a locksmith. I have good old Master Locks that I can still get keyed the same. It’s been 30 plus years and I must have 20 or so floating around.
But a locksmith can get “nicer” locks that will last and can be rekeyed. Keyed alike is a must for me.
   / Padlocks
What about settable combination locks? Anyone have any recommendations?
   / Padlocks #8
I use the brass 4 number locks from Wally World and they have worked pretty good and I don’t have to worry about losing the key. They have held up pretty good out in the weather but not so well in the back of my truck when that get full of grease and mud, but I can clean them up and they still work.
   / Padlocks #9
No reason to get expensive locks. Battery operated cut off tool gets through the best and hardest in seconds. Locks only keep the honest folks honest. I have a set of 8 keyed alike Master locks. Just look through the locks on display and pick out ones with the same number. At Lowes I could have had 12 all the same.
Ron
   / Padlocks #10
I have a Master resettable with 4 dials, but it's a PITA on locks you will be using often, vs simply using a key.
Lay-Mor Sweepmaster 400 Broom Sweeper (A49461)
Lay-Mor...
WHITE CI-7 DRAW WORKS POWERED BY TWIN DETROIT 12.7S (A50854)
WHITE CI-7 DRAW...
John Deere 752 4-Star Hay Tedder - Reliable Ground-Driven Tedding Machine (A51039)
John Deere 752...
2002 JOHN DEERE 450H CRAWLER DOZER (A51406)
2002 JOHN DEERE...
2015 FREIGHTLINER CASCADIA (A50854)
2015 FREIGHTLINER...
16 STEEL SHEETS CURVED (A50854)
16 STEEL SHEETS...
