Packing Peanuts vs. Pests?
/ Packing Peanuts vs. Pests? #1
Diggin It
Super Star Member
I'm thinking, I'm thinking!
LS MT125 TLBM
Middle of the night, brain goes to odd things.
I'll have a void at the base of the walls in the shed I've been working on. I could fill it with dirt but there are the termites. I could fill it with gravel or crushed concrete, but the ground outside is lower and either will probably settle out over time, maybe pushing the lower wall section out. All will retain moisture to a degree and promote rust on the metal walls over time.
Lots of people use styrofoam in various forms for insulation or weatherproofing/waterproofing and insect deterrence. So I go to wondering about packing peanuts. Easy to pour, will settle over time but not pack down or add stress. Won't retain moisture or host bugs.
Is it as stupid an idea as it sounds?
/ Packing Peanuts vs. Pests? #2
I would check carefully. Some are made of starch - they are biodegradable. I've heard stories of how these can attract rodents. Otherwise - those made of styrofoam would probably work fine.
Yeah, the corn grease stuff wouldn't work. Much like corn juice in gas.
I'm thinking of the real ones.
/ Packing Peanuts vs. Pests? #4
I would question the insulation and void filling value. They won't pack tightly and will leave significant air space. I think this would allow air movement and pest movement. Spray foam would be a lot better.
Light Bulb Moment!! :lightbulb: :lightbulb:
Stumbled on some styrofoam panel pieces I had saved many years ago and stuffed up in top of the garage. (Yeah, I'm a pack rat). Should have enough assorted sizes to cut and fill most of the void. It's real styrofoam, the hard white pieces that they might not even make any more. It'll be more stable against settling than peanuts and will withstand pests and moisture even better.
2021 Ford F550 4X4 Service Crane Truck (A62613)
2021 Ford F550 4X4...
2009 Ford Escape SUV (A64557)
2009 Ford Escape...
2014 PUMA  END DUMP TRAILER (A65643)
2014 PUMA END...
2018 KMC 4505 (A64126)
New/Unused Quick Attach Auger (A65583)
New/Unused Quick...
2022 Deere 17G (A64126)
2022 Deere 17G...
