PA 200 ST & LN-25
   / PA 200 ST & LN-25
I have a PA300 too(amazon mis-priced deal) , and I am egear to hear how the hot start/arc force effect wire feed welding.
I took a look on Craigslist tonight and saw an LN-25 listed for $1000. Looked like a newer model in good shape. What would be a good price for a used LN-25?
https://worcester.craigslist.org/tls/5271318261.html
I posted this same subject in the Everlast section over on Welding Web. I made the statement how hot this little welder is. Mark said it may have something to do with the automatic hot start, and arc force.
I know when I Tig weld with my PowerArc 300 I turn the hot start, and arc force off. My Lincoln V350-Pro has adjustable arc force, when using a wire feeder the arc force is called Pinch. The Pinch is really nice for like welding vertical up hill. You turn the Pinch up, and it dries the puddle up, not as flowing, so vertical up hill is a piece of cake to run. Now when flat welding I turn the Pinch down low, and I get a nice flowing puddle.
I just wonder if the adjustable arc force on the PowerArc 300 will do the same.
Personally I think that is high for that LN-25. If it came with full assortment of V-groove, and serrated drive rolls, then maybe! For that LN-25 I think $700.00 is the very most I'd pay.
Whoa.. slow down you experts. What did you just do? Hooked your Stick Welder up to the wire feed of a mig welder?
Or is the wire feeder a dedicated piece of equipment that fancy welders own so they can change the power heads....
Intrigued, will never do it as my Mig is a lincoln 180C but intrigued...
The LN-25s are what we used in the field. You can run Mig through them, if you have a CV power source. If you only have a CC power source like these little stick welders, they run T-11 self shielded flux core wire like a dream. First time I saw a CV engine drive was in the very early 1980s. Oh sure some of the older Lincoln engine drives had an add on CV box.
These LN-25s are a great wire feeder, its amazing all they can do!
   / PA 200 ST & LN-25 #12
The early versions of these voltage sensing feeders were really suited for TGS self shielded wires. They newer generations have gas solenoids, meters, burnback and slick style designs. When the big coal power plants have an outage and they rebuild the burner walls, they run 100' or more cable from the power supply and simply carry the suitcase feeder as they go. With the addition of meters and or digital read out you can monitor and adjust on the fly. You will see 8 pack and 12 pack racks of power supplies and the rack is hard wired to the power source. The welders each grab a feeder and away they go. Very cool to behold.
   / PA 200 ST & LN-25
How about from the PA200 or 300, how would it compare?
Well they won't run Mig, they're CC only welders. Here is what Mig looks like when run on a CC only welder. I did this with my 1966 Lincoln SA-200 engine drive.
Very, very hot!
   / PA 200 ST & LN-25 #15
I doubt the wire feeder would weld nearly as nice as the new Millermatic though...
Is it easy to set the feeder up with shielding gas?
Nope. I have a Millermatic 252 and I just bought a LN-25 to run off my Invertec V-350 for welding heavier material and more amps than the 252 can handle. As bonus I can run the LN-25 off my gas powered welder as well for mobile wire feed welding.
It uses shielding gas no problem or you can do flux core for welding portable outside in the wind.
   / PA 200 ST & LN-25 #16
Thanks I appreciate your experience and info. I'd kicked around getting a wire feeder and using it with my Dialarc, but hadn't considered it could be used with a little stick inverter too. If I went that route it would add a lot of versatility being able to burn stick or wire in the field off my generator, vs just mig or flux core with the 211 like I'm leaning toward. And I do have a few hundred pounds of Atom Arc 7018's! :drink:
Sorry I should have been more clear here, I wasn't saying I thought any Millermatic would do better than a big cv machine with a ln25, but rather running the feeder off a small cc inverter like the Power Arc verses a small Millermatic like the 211.
So let me see if I got this right. In my case I don't have a good option for mobile welding so I could spend 1000$ and get a MM211 that will mig and fluxcore, verses spending 1000$ for a Powerarc and used wire feeder that will stick and fluxcore. Is that right?
A wire feeder is probably overkill for me, maybe I should just get a 211 and a pa300. :D
   / PA 200 ST & LN-25 #17
dntfxr, you have so many options! I suppose only you know for sure what will work best depending on application, situation and budget.
Here's another route to consider: Brand new Lincoln or Tweco 3in1 machines in the $1000 range. Mig Stick DC tig. dual voltage inverters. Put it on your credit card get the airmiles and 3 year warranty.
Here's my Tweco/ Thermal Arc
Happy researching (and shopping)!
Terry
   / PA 200 ST & LN-25 #18
Oops sorry. Just noticed you HAD considered this route in an earlier post
I'd better grab another coffee. :)
Terry
   / PA 200 ST & LN-25 #20
Thanks Terry I'm kinda considering all options right now. BTW good looking welds SA, as usual ;)! I like that bender in the background too, you have all the cool toys!! :thumbsup:
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A50046)
2018 FREIGHTLINER...
1984 Trailmobile Enclosed Van Trailer (A51039)
1984 Trailmobile...
2014 CATERPILLAR 336FL EXCAVATOR (A51242)
2014 CATERPILLAR...
2022 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A51219)
2022 FREIGHTLINER...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
1999 24DTA pintle hitch trailer (A51039)
1999 24DTA pintle...
