P-model arch steel building project
   / P-model arch steel building project #22
I like the Man lift too, The only thing is I would use a belt and lanyard with it. I have used all kinds of man lifts and have seem men catapulted out of them. Tire flex alone is enough to make big movements on the end of a boom. Counter wt probably be a good idea too. I watched a guy on the end of a condor lift get tossed out of a basket and get banged up pretty on the end of the lanyard on his way over the side. Better than hitting the ground of a construction sight though
yeh i tried a full body harness i use when hunting but it didnt allow me the reach i needed to reach over and under the panel at the same time to put a bolt,nut on hard to explain no matter how i attached it, it was in the way. took the risk nothing happend. might get killed driving down the road today in my govt. safe car but i took the risk. as far as counter weight tires are loaded and i tested it strait out with 3 people on it bouncing & we couldnt get the rear tires to lift. plus the concrete made a nice flat smooth surface to work from. it aint the fall that gets you its the sudden stop at the bottom
   / P-model arch steel building project #24
Beautiful JOB on your new garage. The nicest looking garage I have seen a long time. Congratulations!
thanks, cant wait till i have it done & heated.
   / P-model arch steel building project #27
We are having the same nightmare! How in the heck did you get the first panel up? details please! Thank you!
   / P-model arch steel building project #28
I rented a genie lift, crank it up about 6 feet and place it on by hand, then crank. They went up no problem. We did 20 arches in 2 days, the longest time is getting each arch bolted to the last one. We had all the arches pre-assembled on the ground ahead of time, and we had the edge stuff to bolt each one onto.
   / P-model arch steel building project #29
how did you attach lumber to steel for your front and back walls?Any pics of it?
2016 Isuzu NPR Landscape Dump Truck (A55788)
2016 Isuzu NPR...
12'x20' High End Carport (A53316)
12'x20' High End...
2015 Ford F-150 Ext. Cab Pickup Truck (A53422)
2015 Ford F-150...
2022 New Holland Workmaster 120 MFWD Compact Utility Tractor (A55302)
2022 New Holland...
2007 Ford F-150 4x4 Crew Cab Pickup Truck (A55788)
2007 Ford F-150...
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
