oxygen-acetylene Help
/ oxygen-acetylene Help #1
Ridgeman
SE Ohio
JD 4520, JD 595SE, Gator HPX, JD 997
Hi, been a member for a while but this is my first post.
I'm trying to find some info or web sites that deal with using oxygen-acetylene equipment. Seems to be a lot on welding but....
Anyone able to steer me in the right direction?
Thanks
/ oxygen-acetylene Help #5
web page Try this link and good luck. I had bought a torch setup about 1year ago, nice for cutting thick metal . I have used it to braze things a few times also. I use my arc welder for welding mostly.
Just remember to be safe and try and store your cylinders outside if possible.
/ oxygen-acetylene Help #6
Since I bought my Mig, I pretty much rarely use my OA, just to cut something that seems to big or won't fit into the band saw, and if I had a plasma cutter I wouldn't use it for that either.........I could see having an arc welder tho...........
/ oxygen-acetylene Help #7
Ridgeman, Oxygen & acetylene are used mostly for brazing thinner materials ,my usage will be mostly for ornamental gadgets nothing real heavyduty usage. The one fairly heavy duty thing I have done is braze my cracked exhaust manifold muffler ring back together(don't ask /forums/images/graemlins/crazy.gif)
Trying to gas weld anything like 1 1/2" angle is very time consuming and uses way too much O&A
Mig is probably the way to go, But like a previous poster asked , What are your planning to do with it? /forums/images/graemlins/cool.gif
Rotary Auger Motor Attachment (A61572)
Rotary Auger Motor...
UNUSED 2026 INDUSTRIAS AMERICA HYD TILT TRAILER (A60430)
UNUSED 2026...
2014 Chevrolet Equinox SUV (A64557)
2014 Chevrolet...
2024 BOBCAT S76 R-SERIES SKID STEER (A65053)
2024 BOBCAT S76...
2017 Caterpillar 259D (A64126)
2017 Caterpillar...
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
