oxygen-acetylene Help
   / oxygen-acetylene Help #1
Ridgeman
SE Ohio
JD 4520, JD 595SE, Gator HPX, JD 997
Hi, been a member for a while but this is my first post.
I'm trying to find some info or web sites that deal with using oxygen-acetylene equipment. Seems to be a lot on welding but....
Anyone able to steer me in the right direction?
   / oxygen-acetylene Help #5
web page Try this link and good luck. I had bought a torch setup about 1year ago, nice for cutting thick metal . I have used it to braze things a few times also. I use my arc welder for welding mostly.
Just remember to be safe and try and store your cylinders outside if possible.
   / oxygen-acetylene Help #6
Since I bought my Mig, I pretty much rarely use my OA, just to cut something that seems to big or won't fit into the band saw, and if I had a plasma cutter I wouldn't use it for that either.........I could see having an arc welder tho...........
   / oxygen-acetylene Help #7
Ridgeman, Oxygen & acetylene are used mostly for brazing thinner materials ,my usage will be mostly for ornamental gadgets nothing real heavyduty usage. The one fairly heavy duty thing I have done is braze my cracked exhaust manifold muffler ring back together(don't ask /forums/images/graemlins/crazy.gif)
Trying to gas weld anything like 1 1/2" angle is very time consuming and uses way too much O&A
Mig is probably the way to go, But like a previous poster asked , What are your planning to do with it? /forums/images/graemlins/cool.gif
2013 FREIGHTLINER BUSINESS CLASS M2 VACUUM TRUCK (A51406)
2013 FREIGHTLINER...
2008 VOLVO EC460CL (A52472)
2008 VOLVO EC460CL...
AUCTION STARTS HERE @ 9AM (A51406)
AUCTION STARTS...
2022 New Holland Powerstar 90 Tractor with Loader (A51573)
2022 New Holland...
2016 Kia Cadenza Sedan (A51694)
2016 Kia Cadenza...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
