Oxy/Acy-Use flashback arrestors AND check valves?
   / Oxy/Acy-Use flashback arrestors AND check valves? #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
My Purox Acy/Oxy torch does not get a lot of use and after a few year absence I need to dismantle a big piece of tillage equipment. The torch is in good shape and I bought it new maybe 13 years ago and only use it to cut and heat.
I have flashback arrestors on the tank side of the hoses and that's the only way I have used it. In looking for a tip I found I also have a new pair of Lincoln check valves S24041-15R. For some reason I never put them on and must have had a good reason but cannot recall.
Should I use both flashback arrestors AND check valves or am I good with just flash arrestors? Thanks in advance.
   / Oxy/Acy-Use flashback arrestors AND check valves? #2
MSHA encourages protection on both ends, and the arrestors won't protect anything sitting on the shelf. They are "paid for" so I'd hook 'em up.
I run checks at the torch and arrestors at the regulators.
BTW sitting doesn't seem to bother Purox torches. I have some from the 1930s and even the seals are still supple and pass leak checks.
MSHA - Safety Hazard Information - Special Hazards of Acetylene
   / Oxy/Acy-Use flashback arrestors AND check valves? #3
Flash arrestors for sure. Check valves just stop a reverse gas flow. If 1 tank runs out, The other can easily bleed into the empty one. ( dangerous) If you have no worry of that. It's up to you.
Well, I do worry so my plan will be to keep my flash arrestors on the tank end and add the check valves on the torch end. I think I understand better now. Any further commentary appreciated.
   / Oxy/Acy-Use flashback arrestors AND check valves? #5
The MSHA folks have the greatest incentive to be safe, since explosions underground with no immediate rescue are a Bad Thing. No place to run and all that... :(
American Welding Society overview:
www.aws.org/technical/facts/FACT-28.pdf
   / Oxy/Acy-Use flashback arrestors AND check valves? #6
Both.
That was one of the high points of my O/A instructor. I don't know if he had personal knowledge but he sure made a point of repeating his point.
Rc
   / Oxy/Acy-Use flashback arrestors AND check valves? #7
Protection at both ends can save burning up the hose all the way to the regulator.....
Thanks, guys. I did go with both check-valves as well as flashback arrestors.
Screwing up acy-oxy doesn't really give a "do-over" opportunity so I took the high road and spent the extra couple dollars .
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
DeeZee Crossover Aluminum Truck Tool Box - Secure Weather-Resistant Storage for Pickup Beds (A53473)
DeeZee Crossover...
GOODYEAR SET OF 9.5-24 AG TIRES (NEW) (A53473)
GOODYEAR SET OF...
2015 Ford F-250 Knapheide Service Truck (A51692)
2015 Ford F-250...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
VERMEER 605F ROUND HAY BALER (A51247)
VERMEER 605F ROUND...
