Oxy acetylene rig recommendation
   / Oxy acetylene rig recommendation #11
My tanks are on a 99 year lease program. When empty I take the empty tank in and it is replaced with a full tank.
   / Oxy acetylene rig recommendation #12
In 25+ years I've never had a problem exchanging tanks and I've had my tanks exchanged all over the state. I have never been asked for a reciet on the tanks and only had to pay a Hydro fee once.
   / Oxy acetylene rig recommendation #13
I didn't see the Smith brand mentioned. Smith is a very good brand, made in USA (South Dakota, I think) and much of their stuff has lifetime warranty. I don't know if they are clearly superior to Victor, Harris, etc. but I'm pretty sure they're just as good or better and the made in USA factor is a huge plus to me.
   / Oxy acetylene rig recommendation #14
For most general applications, I would go with the genuine Victor 100 series set. I had one of those "Victor compatible" sets, but it was nowhere near the quality of the Victor set I have now. I have cut 1.25 inch plate with mine, and with the right tip, it did a great job. The only thing the 100 series torches don't do well is run a large rosebud tip. I guess they can't flow enough gas and you keep getting blowouts. If you do a lot of heating with a large rosebud, I woud get the big torch body.
   / Oxy acetylene rig recommendation #15
RonR said:
Tnau,
[The thing you need to check, and it should be as easy as calling a couple of gas suppliers, is how does the tank deal work?]
Thanks Ron, I went back to talk to the dealer. He told me two suppliers within 25 miles that would exchange these tanks. They are both independents. He said the only issue I may have is if the certification runs out since it will take me so long to use a tank of gas/oxy.
Thanks
Terry
   / Oxy acetylene rig recommendation #16
Victor, Harris, Smith, or Purox are all good equipment. Victor is probably the easiest to find regularly. I have a Purox setup because I like their torches better - but, I usually have to order the speciality tips (rosebud for example).
   / Oxy acetylene rig recommendation #17
Smith does make a excellent quality tourch and is made in the USA. I recently bought one of their heavy duty Dual Guard cutting, welding and heating kits and a Gas Axe demolition cutting tourch handle. I needed to add another tourch outfit to the shop and since the old Smith tourch set I have used for over 15 years has never given me problems I figured I would go with them again. They do have a "Lifetime Series" (the ones I bought) and the warrantey covers everything, o-rings, seals, tourch tips, handle, etc... for life to the original purchaser.
   / Oxy acetylene rig recommendation #18
I bought a Victor 100 set about 25 years ago. Had no idea which brand to buy but the local dealer had this set on sale and it was a very good price. Lucky for me I chose the right one. Have been using it ever since. I've gone thru a few tips but that's because they get beat up. Personally, I would not go with an off brand on something this important.
No matter where I go I can always get Victor tips. I used to weld with it but now I leave that to the MIG welder. But I still do alot of brazing, cutting and silver soldering.
   / Oxy acetylene rig recommendation #19
Hi!
I have an old used Sears set. I have had it for 25 years and had no problems. I don't know how much trouble getting parts is as I have never needed any. Got it at a garage sale cheap.
I would also think about using propane instead of acetylene. The tanks are MUCH cheaper - like $20 and refills are as close as Home Depot and even some gas stations. It takes different cutting torch tips and a gauge/regulator adapter. Make sure you can get the propane cutting tip before you buy the set.
Propane actually puts out quite a bit more heat than acetylene. I am talking BTUs per pound of gas used. Acetylene will put out a higher flame temperature but not as much heat, if this makes sense. I have cut railroad track with my setup without the slightest issue. Cuts them like butter.
For pre heat, bending and cutting propane works better, costs less to refill/use and is easier to find-AND- it won't blow up like an acetylene tank will if it's hit real hard. :eek:
Greg
   / Oxy acetylene rig recommendation #20
I bought a new set o Smith last year and use propane through them. You are right gclark propane is a better heat. they told me ya can't gas weld with it . Have youtried to gas weld with it ? I haven't tried it yet but have been meaning to. I think any gas that will melt metal can be used to weld 2 pieces of metal together.think of it this way the old time blacksmith forged metal together with a fire of wood in a fire pit. So give me one good reason a man can't weld with propane.
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A58017)
2018 FREIGHTLINER...
2006 Keystone Laredo 29RL 31ft. T/A 5th Wheel Travel Trailer (A55853)
2006 Keystone...
1995 Rinker Captiva 190 (A56435)
1995 Rinker...
2017 Freightliner MT55 Step Van (A56858)
2017 Freightliner...
PULL TYPE CONCESSION STAND (A54757)
PULL TYPE...
2013 TRAVIS BODY & TRAILER ALUMINUM BELLY DUMP TRAILER (A58214)
2013 TRAVIS BODY &...
