oxy/acetylene filler metal?
   / oxy/acetylene filler metal? #11
I'll ditto coat hangers.
I tried using a coat hanger, but the melted plastic stunk & got all over everything /forums/images/graemlins/grin.gif (only kidding).
   / oxy/acetylene filler metal? #13
Same here on the coat hangers. I've never compared cost of rod versus coat hangers, but for the minimal amount of gas welding I do, coat hangers work great.
My neighbor is a certified welder and he uses coat hangers too. I had a metal hydraulic line for my blade bend in half by a tree on my dozer. I cut it and cleaned up the edges, but had him weld it back together. He used a coat hanger. I don't know the preasure that line handles, but it doesn't leak at all.
Eddie
   / oxy/acetylene filler metal? #14
Coat hangers when you run out of the copper coated rod and copper electrical wire when you run out of brazing rod. Don't remember the flux I used with the copper wire but it worked well in most cases. I once used gold rod when I gold flossed hydraulic lines when I worked for Southern Pacific when I was a kid.
Farwell
   / oxy/acetylene filler metal? #15
either rod you have there will work nicely. You never know what kind of cheap metal is in a coat hanger, you are better off with real filler metal that has been rated unless you are welding 2 coat hangers together, then I would use a coat hanger as a filler.
Aerway Tillage Tool (A59814)
Aerway Tillage...
2016 Husqarvana YTA22V46 46in Riding Mower (A56859)
2016 Husqarvana...
2023 FORD F-250 STX (A58214)
2023 FORD F-250...
CASE ROOT PLOW (A58216)
CASE ROOT PLOW...
2025 JMR 78in Dual Cylinder Brush Grapple Skid Steer Attachment (A56857)
2025 JMR 78in Dual...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A56438)
2020 Westfield MKX...
