Owning a small tractor is a blessing.
   / Owning a small tractor is a blessing. #1
tacticalturnip
Elite Member
NW Atlantic
Kioti CK2610HST
Just having a tractor around is an absolute blessing for me; it's not a need, it's something I'm able to afford that makes life so much easier.
A few days ago I managed to obliterate a mowing blade in a way that was new for me, directing it straight into the ground. This made moving the lawnmower difficult.
I just brought the Kioti over to the Cub Cadet and lifted the mower in the air. I've never had an easier time removing the blades. I did the same a few days later when I put the new blades on. With the new blades on, forgetting about the previous days rain, I immediately sank the Cub in mud.
A small tractor suited this recue effort far more than the F350 would have; a small tractor is a blessing.
I mowed the upper area and then put my toys away, I'll try again this weekend.
   / Owning a small tractor is a blessing. #3
View attachment 3569309View attachment 3569310View attachment 3569311
View attachment 3569312View attachment 3569314View attachment 3569313
From the pictures I would say you need the tractor. That's a lot of turf.
   / Owning a small tractor is a blessing. #4
My wife agrees!
She often is heard saying, "if it saves just one trip to the Emergency Room" (or the chiropractor)
May I suggest using jack stands or hydraulic cylinder blocks when working under mower, tractor hydraulics are nor fail safe and have been know to release dropping load.....
You are absolutely right, using jack stands would have been the smart thing to do, and I have them.
It only takes one mistake; I was not thinking, and that's said by so many others in a bad way after the fact- assuming they are still around. I don't mind taking this scolding because I knew better, and still let convenience lead my way.
I would absolutely give my kids hell for not putting safety first, but look at me not taking my own advice.
   / Owning a small tractor is a blessing. #8
Just yesterday in a town in S. Indiana, a 16 yr old boy was working under his Ford truck held up with a jack. The jack failed and the boy was killed. He was not using jack-stands.
2011 20ft. Anderson Lowbed Trailer (A56859)
2011 20ft...
2012 Kenworth T800 T/A Wet Kit Sleeper Cab Truck Tractor (A55973)
2012 Kenworth T800...
FENCE PANELS (A58214)
2016 FREIGHTLINER  CASCADIA (INOPERABLE) (A58214)
2016 FREIGHTLINER...
5' SCRAPE BLADE, 3PT (A52708)
5' SCRAPE BLADE...
VACUUM PLANTER PLATES (A52708)
VACUUM PLANTER...
