jeff9366
Super Star Member
- Joined
- Jan 14, 2011
- Messages
- 12,787
- Tractor
- Kubota Tractor Loader L3560 HST+ ~~~~~~~~~~~~~ 3,700 pounds bare tractor, 5,400 pounds operating weight, 37 horsepower
What I want to do is clean up the thorny brush and vines that are everywhere, cut up and remove all the dead/down trees.
So, with all that in mind, what would you buy if that were your ~4 acre property? Do you think that the B3350 from Kubota or the JD 2032R with front-mounted snowblowers would be up to the work I have in mind?
The vines are wild grapes, Vitus rotundfolia, and Virgina Creeper. The thorny brush/vines looks mostly like Smilax, which is hard to eradicate, plus some wild climbing rose. Go to your local Tractor Supply Co. (TSC), Rural King or Southern Co-op and buy 2-1/2 gallons of an herbicide concentrate labeled for "briars". You will have several choices. Herbicide for vine eradication must be applied while vines are actively in growth, so spray before the weather turns cool.
Chop up what you can first with the Flail Mower or Bush Hog, then spray residual verdure around tree trunks.
You have a big job. Be sure to wear long pants, long sleeves, gloves, a hat and safety glasses and bathe when you are done spraying; do not wait until the end of the day to bathe.
Both the B3350 and 2032R are entirely adequate for four acres plus snow.
Bigger/heavier equals faster, not better. An L model, best of all a 'Grand L' model, will weigh more, be more stable and provide more traction.
In January 2013 I paid $27,500 for my 'Grand L' 3560 tractor-loader with following options: LA805 loader, SSQA L2296 HD RB bucket, two 5/16" chain grab hooks welded on bucket, R4 tires and Draft Control. (Draft Control = I plow) No sales tax in Florida. SOME TRACTOR!
Like Pappy, I spreadsheet important purchases in process of consideration. I calculate cost per pound in addition to entering factory specs.
