Overweight
/ Overweight #11
Your GCWR doesn't surprise me at all. Mine is GVWR of 15K, and I'm told that my GCWR is somewhere around 19K. I can not find my GCWR anywhere, including several calls to GMC. They are assembled as chassis/cab, so GVWR is listed, not GCWR. Therefore, when I registered it, I did not assign a GCWR value.
I guess we'll see what happens if I get pulled over.
/ Overweight
If "toy" classification means I don't need DOT numbers, I'll take it; besides, mine's got 4x4, gets 12mpg and cost only $47K and is not for business, just farm related stuff e.g. I need cross the border into NY. for 3yds. organic compost/topsoil mix and don't want to get busted on the way back for possession of manure with intent to distribute. I checked out that FedDotRegquiz website and it seems to want to include (suck in) everyone. I have commercial plates but am not in business and do not haul for $ or barter.
Anyway, the plate inside the truck door says exactly what the Fuso site says but there is no mention of the 17045 GCVWR, neither does my registration. My intention is to stay within weight restrictions thus the post.
I ordered a hydraulic hanging scale 2000lb. range so I can parse out components to stay under but; like I said, I'll need to make more trips and don't know how I'll load up once I drop off the tractor.
/ Overweight #13
Guys, remember that only your trucks' actual weight counts against you. So if you have a truck with a GVWR of 15,000 lbs and a GCWR of 22,000lbs, it doesn't mean you're limited to a 7,000lb trailer. It means if your truck actually weighs 10,000lbs at the time you're pulled over, you have a limit of 12,000 lbs for the trailer.
dyrtydeed,
I think you'd be more like 23-24K. That's a heavy duty truck you have there with plenty of available pin weight!
/ Overweight #14
Yeah, I know. Rear axle GAWR is 11K. Truck weighs 10K. Trouble is it's got a stock 6.5L TD. I'm sure the 5.13's help, but I need to lose the "Kitty" and run a 4" exhaust.
It needs to earn it's keep since I just bought it before it get's any mods...;)
/ Overweight #15
Engine power is actually a small factor. Brakes, springs, frame strength are the big factors. I've had 185hp medium duty dumps that are rated to pull a full size backhoe. :)
Wow, she weighs 10K empty? More than I thought.
/ Overweight #16
em14 said:
As I thought about the GCVWR as compared to GVWR it looked to me as though the MFG ( Mitsubishi ) doesn't want trailers pulled by this truck!
Leo
Most 4x4 trucks i know in Europe, have a lower tow rating than their 2wd brothers... 4wd puts bigger strain on the drive components because wheelspin isnt a torque limiting factor on the driveline anymore.
/ Overweight #17
Normally those are the safety limiting factors, the factors that keep the truck in control of the trailer, but that truck is only a 4 cylinder, like you said his truck is pretty heavy duty so in this case IMO it has to be a power limit factor.
Our little 3/4 ton domestic pick ups pull 5 ton trailers no problem, but some of them have a full 2 times the engine power output than that 4 cylinder.
Tractorganic,
How did your truck pull when loaded up to that 18,930 pounds, I'm sure it wasn't a speed demon but was it able to safely get out of it's own way? I think in your case being over on the GCWR, there wont be the issue of slowing the load down and controlling it but more getting it moving, like pulling hills and merging into traffic.
John,
/ Overweight
I live on a steep hill too tough for bicyclists. The truck and trailer brakes had no problem going down hill on the ride to the CAT scale w./ 18k+ gross. Across the CT River I have to climb a long steep grade to Rt. 9 and I crawled down to 40 in the 50 zone. After that pretty smooth sailing at 60 down 9 to 95 west to the Branford TA scales. On the return I used flashers once when I bogged down to 50 on a highway hill.
I made a run West on I-84 with a significantly lighter load (about 5k gross) of a car on this trailer so I could drop the Fuso and trailer at the dealer for work and drive the car home. Those I-84 hills are a killer and I used flashers a lot, but so were other rigs.
By the way home to dealer is 80 miles and if I had CT farm plates I'd be limited to 50 mile range to dealer so I'd have to put the Fuso on a trailer to stay legal!
/ Overweight #19
Given what you wrote, you NEED USDOT numbers.
The federal government has proclaimed that 10,001 pounds and over means you need the numbers for commercial.
You have commercial plates - you're commercial -> duh. Try telling the smiling man in blue your are personal only with commercial plates. Let us know how that one turns out!
You are doing "Farm related stuff" - that's commercial by definition.... but might just might have an exclusion from the USDOT number BS.
You are crossing state lines. Any farm exclusion is lost when crossing state lines as federal and not state statutes apply.
Good luck!
jb
/ Overweight #20
Why exactly do you have commercial plates?
Because like John Bud says...you are a dead duck if you are stopped...
RDS Manufacturing 70307 48 Gallon L-Shaped Transfer Diesel Fuel Tank (A59230)
RDS Manufacturing...
2017 ISUZU NPR 18 FT  BOX TRUCK (A59905)
2017 ISUZU NPR 18...
2012 Ford F-150 4x4 Pickup Truck (A59230)
2012 Ford F-150...
2022 Bobcat T66 (A53317)
2022 Bobcat T66...
2018 KAUFMAN 44 FT T/A  CAR CARRIER TRAILER (A59906)
2018 KAUFMAN 44 FT...
2015 Lincoln MKZ Sedan (A59231)
2015 Lincoln MKZ...
