Overseeding Bahia Grass
/ Overseeding Bahia Grass #1
nickgalyon
I live in South Florida. I need to overseed a grass taxiway on our airpark. It is a sandy soil with patchy Bahia grass. What do I need to attach to my JD 790 to scratch up the surface enough to plant the grass seed, without plowing it up to the point it is too soft to taxi airplanes over? I have never used a disk harrow. Can it be set to just scratch up the surface? I don't think a landscaping rake would make a slit to bury the seed.
I am getting lots of work done with my 790 and appreciate the advise I got here on installing grab hooks and loader shims.
/ Overseeding Bahia Grass #2
I was just reading the instructions on a bag of expensive grass seed yesterday that basically said: Mow the grass in the area to be over seeded. Spread the seed using your choice of methods. Rake the grass so the the seed makes contact with the soil. make sure the area is kept somewhat damp until the grass seed germinates.
Think I would use a landscape rake turned around backward so as not to move any dirt, just to make sure that the grass seed gets filtered down between the existing grass blades and is in contact with the soil.
Thanks for the information. I have a home made rake. I'll give it a try in my yard.
Nick
2007 FREIGHTLINER CL120 6x4 T/A DAY CAB TRUCK TRACTOR (A59914)
2007 FREIGHTLINER...
2012 COMPTANK ACID TRANSPORT TRAILER (A67714)
2012 COMPTANK ACID...
SARLO (A64557)
SARLO (A64557)
2017 FREIGHTLINER CASCADIA  125 6x4 T/A  SLEEPER TRUCK TRACTOR (A69167)
2017 FREIGHTLINER...
2000 Mack DM690S T/A 2,000 Gallon Water Truck (A66736)
2000 Mack DM690S...
2003 Ford E-450 Super Duty Passenger Bus (A61573)
2003 Ford E-450...
