Overrunning clutch, L2250
/ Overrunning clutch, L2250 #1
albe
I recently purchased a Kubota L2250 with a dual clutch. Do I have to install an overrunning clutch when using a shredder? Thanks
Albe
/ Overrunning clutch, L2250 #2
Well, I'll take a guess since nobody else answered.
No
I assume a dual clutch is the same as a two stage clutch. If that's the case, then I think the PTO is disengaged when you depress the clutch and you can shift from forward to reverse without the "momentum" of the blades spinning and carrying you forward.
I had a Yanmar 1500 with single stage clutch and learned quickly that without the ORC, you really had to be on your toes and anticipate your stops.
/ Overrunning clutch, L2250 #3
My quess would also be No.
I'm not familiar with that particular machine, but most likely it has and internal overrunnig clutch.
Thanks. I was hoping for that answer since the PTO shaft has no hole for the roll pin of the overrunning clutch. I know I need one for my old Ford tractor. I'm new with this "modern" stuff. Albe
/ Overrunning clutch, L2250 #5
I think the two stage clutch was introduced (long ago) for precisely this issue, the tractor being powered by the spinning mass of the attachment. The marketers called it "independent pto", I think.
On my first Kubota (which had a 2-stage) , the main clutch wore quicker than the pto clutch - so after adjusting the linkage for the wear it got to a point where the pto no longer disengaged at full pedal travel. The answer was a new main clutch.
Rightline LP5C-C5B0-A 42in Hydraulic Side Shift Forks and Frame Forklift Attachment (A61572)
Rightline...
2011 BEAST 48 ELECTRIC RTV (A64280)
2011 BEAST 48...
2019 HYDREMA 922F HM ARTICULATING DUMP TRUCK (A65053)
2019 HYDREMA 922F...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
UNUSED WOLVERINE 6' SLIP ON FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
20ft. 2-Door Shipping Container (A61572)
20ft. 2-Door...
