Overrunning clutch, L2250
   / Overrunning clutch, L2250 #1
albe
I recently purchased a Kubota L2250 with a dual clutch. Do I have to install an overrunning clutch when using a shredder? Thanks
Albe
   / Overrunning clutch, L2250 #2
Well, I'll take a guess since nobody else answered.
No
I assume a dual clutch is the same as a two stage clutch. If that's the case, then I think the PTO is disengaged when you depress the clutch and you can shift from forward to reverse without the "momentum" of the blades spinning and carrying you forward.
I had a Yanmar 1500 with single stage clutch and learned quickly that without the ORC, you really had to be on your toes and anticipate your stops.
   / Overrunning clutch, L2250 #3
My quess would also be No.
I'm not familiar with that particular machine, but most likely it has and internal overrunnig clutch.
Thanks. I was hoping for that answer since the PTO shaft has no hole for the roll pin of the overrunning clutch. I know I need one for my old Ford tractor. I'm new with this "modern" stuff. Albe
   / Overrunning clutch, L2250 #5
I think the two stage clutch was introduced (long ago) for precisely this issue, the tractor being powered by the spinning mass of the attachment. The marketers called it "independent pto", I think.
On my first Kubota (which had a 2-stage) , the main clutch wore quicker than the pto clutch - so after adjusting the linkage for the wear it got to a point where the pto no longer disengaged at full pedal travel. The answer was a new main clutch.
KUBOTA ZD1211 (A53084)
2016 Dodge Journey SUV (A53424)
2016 Dodge Journey...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A53473)
2016 RAM 5500...
2018 GENIE GTH-844 TELESCOPIC FORKLIFT (A52706)
2018 GENIE GTH-844...
Beverage-Air UCR27-A 27in Undercounter Refrigerator (A51695)
Beverage-Air...
