Overrun clutch on 455 rear PTO?
   / Overrun clutch on 455 rear PTO? #1
aariel
Seneca Falls, NY
John Deere 455
I've got a rear PTO on a JD 455 and I'm curious if I should add an overrun clutch when I use a 4' rotary cutter (brush hog). I've looked through the tech. manual and there doesn't appear to be one built in. There is a PTO brake and I'm concerned that trying to stop the rotary cutter will wear that brake out prematurely.
-Paul
   / Overrun clutch on 455 rear PTO? #2
I don't have an overrunning clutch on my MX5 as I prefer to use the engine to slow the cutter rather than letting the cutter coast on. Not sure how the 455 PTO clutch will handle it, but I would think that a simple, gradual scale back of throttle would suffice.
Owning a 455 I can't really imagine a 4' hog behind it on anything other than exceptionally flat ground. I could park my 455 on top of my MX5 and would suspect near the same with a 48" cutter.
2017 TAKEUCHI TB240 EXCAVATOR (A52705)
2017 TAKEUCHI...
VERMEER RTX250 WALK BEHIND TRENCHER (A52705)
VERMEER RTX250...
2018 KENWORTH T680 SLEEPER (A54607)
2018 KENWORTH T680...
UNUSED WOLVERINE CB-11-750F HYD CONCRETE BREAKER (A54757)
UNUSED WOLVERINE...
