Overly-tight 3ph lever on 2520
   / Overly-tight 3ph lever on 2520 #1
GordNovo
near
Hello,
I'm experiencing a weird issue with my 2520. Would love to hear if anyone's experienced it......
I've noticed the 3ph lever has become much harder to move forward and back (down and up) as of late. When I say hard to move, I mean you really gotta apply pressure to get it to go in either direction. I tried going back and forth quickly a few times while running and while machine is off, but it's made no difference. The 3ph still raises and lowers as per normal.
Any thoughts?
PS> I've got 25 hrs on the clock.
GordNovo
   / Overly-tight 3ph lever on 2520 #2
Mine did that a while ago... A little grease on the joints and the friction plate cured it right up.
   / Overly-tight 3ph lever on 2520 #3
Mines always been kinda tight since i had it. i never thought much
of it. I may grease it a bit. ......:)
Oh.. ok.. good. I'll give that a try.
GordNovo
   / Overly-tight 3ph lever on 2520 #5
I used penetrating oil on mine and it fixed it for a while. Grease should work better. JC
   / Overly-tight 3ph lever on 2520 #6
Thanks kenny , I went out tonight and shot a little chain and cable lube on the joints and the slide. Now its nice and smooth....:)
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A55851)
2019 Caterpillar...
2017 PETERBILT 579 DAYCAB (A55745)
2017 PETERBILT 579...
2013 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400LB Crane Service Truck (A53422)
2013 Ford F-550...
UNUSED AGT TAS-50X PTO Driven Tiller (A47477)
UNUSED AGT TAS-50X...
2018 John Deere 460E Articulated Dump Truck (A55302)
2018 John Deere...
Swict 78" Bucket (A53316)
Swict 78" Bucket...
